Custom indexable tools
Author Brandt Taylor
April 01, 2024 - 04:00pm
I usually make a small number of parts per order, often one or two. My main customer is a builder of industrial machinery. I have made parts for their machines since 1995. Over the years they have built a great variety of machines and I have made thousands of different parts for those machines. Many of their machines are in operation after decades of use. If somebody out in the field calls my customer for a repair part, my customer calls me. Then I look in my files, find the drawing of the needed part, look for any notes or CNC program I used before, and then make the part again.
Recently, my customer presented me with a very different situation. They have a family of machines that use a part that might be called a consumable. The part is a knife made of A2 tool steel that is used to cut cardboard and eventually wears. This was a high-volume job for me and required a different strategy than I normally use. One of the features on the part is a deep slot with a full radius bottom and a specific width. The volume and geometry of the slot called for an indexable insert slotting cutter. A problem arose because the radius of the slot was not available with off-the-shelf inserts.
Figure 1
Figure 1
Figure 2
Figure 2
I found my solution at Cutting Tool Technologies Inc. in Wilton, New Hampshire. They make an array of standard indexable tools for slotting, as well as endmills, chamfer mills, radius cutters, turning tools, indexable broaches and others. They also make custom indexable tools. I called and talked to an engineer at CTT and explained my problem. The CTT people came up with a cutter design. I didn’t have to provide a drawing because they understood what I was talking about. Their design for my application uses an insert with a custom geometry so the slot could be finished in one pass. They made a slotting cutter with pockets to fit the custom insert. I got a quality tool at a reasonable price in two months. It all worked well.
Figure one shows the tool that CTT made for me. It is a 6" -dia. cutter with a 11/4-dia. hole to mount on an arbor. The pockets mount 12 round, 0.219" -dia. inserts with a positive rake angle. The carbide inserts have a titanium nitride coating.
They also make more complex specials than the one I got. Figure two shows an example of what they can do. It’s a muti-insert indexable endmill with an integral V-flange shank. It’s a tool designed to minimize tool deflection and maximize metal removal in a production environment. If you have an idea for a tool you need, a sketch or engineered drawing can be useful but is not necessary. Smart people working together makes work go smoothly.
  • arbor
    arbor
  • endmill
    endmill
  • indexable insert
    indexable insert
  • rake
    rake
  • shank
    shank
  • slotting
    slotting
    Machining, normally milling, that creates slots, grooves and similar recesses in workpieces, including T-slots and dovetails.
  • titanium nitride ( TiN)
  • turning
Author
978-838-2979
Brandt Taylor is owner of Berlin, Massachusetts-based Taylor Engineering, a machine shop and manufacturer of lathe chuck jaws. He can be reached at gbrandttaylor@gmail.com. For more information about the chuck jaws, visit www.stopjaws.com.
