Arbor designed for grinder producing shaped bone fragments
January 19, 2016 - 06:00pm
HSK50E balanceable grinding wheel arbor
Briney Tooling Systems, Bad Axe, Mich., recently worked closely with a leading medical manufacturer to develop a special HSK50E balanceable grinding wheel arbor for a precision CNC grinding machine producing shaped bone fragments for surgical grafting, according to a company news release issued Jan. 19.
The arbor required a special anti-bacterial/viral chrome plating to comply with the demanding requirements of ISO 13485 for medical OEMs and contract manufacturers, Briney reported.
Briney credited its ability to design, produce and deliver the arbor to the customer in 6 weeks to the company's in-house CNC turning and grinding capabilities, including in-plant heat treatment where the control of the carburizing and hardening process ensures that all tools have 0.050 minimum case depth to maximize tool life and reduce distortion.
  • arbor
    arbor
  • carburizing
    carburizing
    Absorption and diffusion of carbon into solid ferrous alloys by heating, to a temperature above the transformation range, in contact with a suitable carbonaceous material. A form of casehardening that produces a carbon gradient extending inward from the surface, enabling the surface layer to be hardened either by quenching directly from the carburizing temperature or by cooling to room temperature, then reaustenitizing and quenching.
  • grinding
  • grinding machine
    grinding machine
  • grinding wheel
    grinding wheel
  • hardening
    hardening
    Process of increasing the surface hardness of a part. It is accomplished by heating a piece of steel to a temperature within or above its critical range and then cooling (or quenching) it rapidly. In any heat-treatment operation, the rate of heating is important. Heat flows from the exterior to the interior of steel at a definite rate. If the steel is heated too quickly, the outside becomes hotter than the inside and the desired uniform structure cannot be obtained. If a piece is irregular in shape, a slow heating rate is essential to prevent warping and cracking. The heavier the section, the longer the heating time must be to achieve uniform results. Even after the correct temperature has been reached, the piece should be held at the temperature for a sufficient period of time to permit its thickest section to attain a uniform temperature. See workhardening.
  • turning
04/25/2024
04/16/2024
