MC Machinery Systems Inc. names Midwestern laser distributor
November 01, 2018 - 02:45pm
MC Machinery Systems Inc.Chicago, IL – MC Machinery, a specialist in high-precision wire and sinker EDM, 2D and 3D laser, milling, and press brake machines, announced the appointment of Black Rock Machinery, LLC, as the new distributor of Mitsubishi Laser in Kansas and Missouri.
Founded in 2005 by Mitch Brown and Don Patterson, Black Rock Machinery is a machine tool distributor specialized in fabrication machinery for the metalworking industry. The company covers Kansas and Missouri for both new and used machinery. It sells and services fabrication machinery for structural, plate, sheet metal, and coil steel through thermal cutting, punching, bending, sawing, shearing and other process methods.
“MC Machinery’s reputation in terms of production and service made this an easy partnership decision,” says Brown. “We’re delighted to partner with them to continue serving our customers with the latest laser machining technology.”
Black Rock Machinery will distribute all of Mitsubishi Laser’s product offerings.
“We are excited to have Black Rock Machinery represent us in the states of Kansas and Missouri,” says Bill Coleman, Midwest regional sales manager. “Their company philosophy is a perfect match to what MC Machinery expects in a distributor.”
  • gang cutting ( milling)
  • laser machining
    laser machining
    Intensified, pulsed beams of light generated by lasers—typically carbon dioxide or neodium-doped yttrium aluminum garnet (Nd:YAG)—that drill, weld, engrave, mark, slit and caseharden. Usually under CNC, often at both high cutting rates (100 linear in./sec.) and high power (5kW or more). Lasers also are used in conjunction with in-process quality-control monitoring systems allowing measuring accuracies of 0.00001".
  • metalworking
    metalworking
  • milling
  • sawing
    sawing
05/16/2024
05/15/2024
