MC Machinery Systems Inc. names Northeast distributor
December 03, 2018 - 01:45pm
MC Machinery Systems Inc.Chicago, IL – MC Machinery, a specialist in high-precision wire and sinker EDM, 2D and 3D laser, milling, and press brake machines, announced the appointment of ProMac Technologies, LLC (ProMac) as the new distributor of lasers and press brakes in the northeast region.
Founded in 2012 by Bob Lauer, ProMac is a machine tool distributing company specialized in metal fabricating machinery sales such as flat sheet cutting CO2 and fiber lasers, coil-fed fiber lasers, fiber tube lasers, CNC press brakes, CNC panel bending, metal finishing systems, sawing and other industry related technologies.
“I started in the machine tool world as a Mitsubishi EDM installation and service technician at MC Machinery over 30 years ago,” says Lauer. “I am delighted to be back home with Mitsubishi to assist in the growth and expansion of MC Machinery’s sales and market presence in this newly appointed region of Delaware, New York, New Jersey, East Pennsylvania and Maryland.”
ProMac’s vast industry experience will enable enhanced consultation of MC Machinery fabricating products, geared specifically toward each customer’s unique requirements to improve efficiency, increase productivity and ultimately increase their overall profitability.
"We look forward to working with ProMac and to have them represent us in the Northeast," says Shane Herendeen, North America Sales Manager at MC Machinery. "The company provides outstanding service and support for its customers and its values align with our growth initiatives."
  • flat ( screw flat)
    flat ( screw flat)
  • gang cutting ( milling)
  • milling
  • sawing
    sawing
05/16/2024
05/15/2024
