Rush Machinery showcases multiple technologies at trade show
April 06, 2023 - 07:30am
Rush Machinery's FC-350W Wheel Truing and Dressing Machine
At this year’s Eastec trade show, Rush Machinery plans to display the FC-350W wheel truing and dressing machine with new accessories and functionality as well as the Auto-Cut carbide rod cut-off machine.
Eastec is scheduled for May 16–18, 2023, in West Springfield, Mass.
The company says that the FC-350W is designed for ease and efficiency in truing and dressing of flats, angles, and radii on diamond and CBN single wheels and multiple wheel packs. The FC-350W allows the user to dress the diameter, profile, and sides of the wheels without taking the wheel pack apart. The optional guarding has four clear acrylic pivoting sections that allow for easy access. A retrofit may be performed by a Rush service engineer if requested.
The machine also comes installed with RushVision, a software designed to make truing and dressing easy and customizable. RushVision aids in high precision, high tolerance work, and truing complex forms and radii up to 2” (50mm). The software includes drawing templates for most common wheel shapes and allows users to import from CAD via USB port or networked PC.
Also available for the 350W Wheel Truing & Dressing Machine is the On-Machine Balancing System Option. The balancing system is seamlessly installed onto Rush Wheel Truing & Dressing Machines. No separate screens or computers are required.
Auto Cut carbide rod cut-off machine
CNC “Auto-Cut” Carbide Rod Cut-Off Machine.
Carbide rod cut-off machine
The company will also showcase the CNC “Auto-Cut” Carbide Rod Cut-Off Machine. The “Auto-Cut” can double the production rate for cutting carbide and hardened steel rod when compared with manual cut-off machines.
It has easy-to-use CNC controls with a touchscreen operator interface. Parameters can be quickly set for rod diameter and length. The machine automatically loads and cuts rods from a large-capacity magazine. The capacity of the “Auto-Cut” is .055” (1.4mm) to 1-9/16” (40mm) diameter carbide rod, up to 16” long, and it comes standard with a flood coolant system.
A new option for the machine available now is the Automated Tool End Cut Off. An adjustable clamping mechanism allows users to automatically cut tool ends and shanks of varying lengths while retaining the ability to cut rods. A short piece loader option is also available.
  • coolant
  • cubic boron nitride ( CBN)
  • dressing
    dressing
  • tolerance
    tolerance
  • truing
    truing
    Using a diamond or other dressing tool to ensure that a grinding wheel is round and concentric and will not vibrate at required speeds. Weights also are used to balance the wheel. Also performed to impart a contour to the wheel’s face. See dressing.
05/16/2024
05/15/2024
