United Grinding North America partners with Dynamic Machine
March 10, 2020 - 12:45pm
March 10, 2020 – United Grinding North America Inc., Miamisburg, Ohio, announced it has entered into a partnership with Dynamic Machine of Detroit, a Troy, Michigan-based CNC equipment dealership. For those United Grinding North America customers in the Michigan territory, the partnership will further strengthen grinding machine sales, service and application support.
With over 200 years of combined machine tool and manufacturing experience, Dynamic Machine will provide Michigan manufacturers with a local advanced technical center for United Grinding-brand machine demonstrations, test cuts, turnkey projects and training. The dealership also offers machine retrofits and upgrades, as well as engineering services.
According to Dynamic Machine co-owners Vince Meleto and Greg Sandler, the company’s reputation for excellence is one based on years of close customer relationships and thousands of machine tool installations. As such, they will offer United Grinding North America’s customers that same level of attention and expertise.
  • grinding
  • grinding machine
    grinding machine
05/16/2024
05/15/2024
