United Grinding showcases equipment at EMO Hannover 2023
September 05, 2023 - 07:30am
United Grinding
The United Grinding Group, a leading manufacturer of grinding, eroding, laser and measuring machines, is showcasing 16 grinding machines, new innovations and updates from its Customer Care team at the EMO 2023 trade show in Hannover, Germany.
The show is scheduled for Sept. 18 to 23. With its special exhibition area this year in Hall 11, Booth E34, the Group is placing a focus on Customer Care. This includes all products and services that accompany customers during the service life of their machines and support them in efficient production, all the way from start-up to retrofit.
Visitors will also get information about all of United Grinding’s digital assistance systems. These include Production Monitor, Service Monitor and Remote Service, which are grouped under the Digital Solutions offering. In addition, the latest digital solutions will be presented at EMO.
On top of this, booth visitors can look forward to several innovations and highlights among the 16 machines on display:
  • Blohm, the surface and profile grinding machine specialist, is celebrating a world premiere: the Planomat XT 408 with automatic workpiece loading and unloading. An exciting new solution for the internal machining of hydraulic motor stators.
  • Studer will also have a cylindrical reveal: an innovative automation solution that will be on display on the S31 universal external cylindrical grinding machine.
  • Walter will present the innovative Laser Contour Check measuring system for the first time at EMO. The tool grinding feature results in highly accurate, non-contact measurement of various tool parameters on cylindrical tools, which is now also available as an option for the Helitronic Micro and Helitronic Mini Plus tool grinding machines.
The machines also allow users to experience groundbreaking C.O.R.E. technology. This proprietary operating system creates the basis for a new generation of machine tools, with simple networking, intuitive smartphone-like operation and the ability to use modern software applications directly on the machine.
  • cylindrical grinding
    Grinding operation in which the workpiece is rotated around a fixed axis while the grinding wheel is fed into the outside surface in controlled relation to the axis of rotation. The workpiece is usually cylindrical, but it may be tapered or curvilinear in profile. See centerless grinding; grinding.
  • grinding
  • grinding machine
    grinding machine
05/16/2024
05/15/2024
