A 980 TZ Special Cutoff Wheel
August 01, 2014
KLINGSPOR's newly formulated 0.8mm (.031") A 980 TZ Special cutoff wheel enhances performance and safety. This precision cutoff wheel is reportedly ideal for thin gauge metal fabrication, precision cutting, burr-free cuts or extremely tough to cut alloys.
Available in both 4-1/" and 5" depressed center, the A 980 TZ Special is packaged in a sealed plastic container to maximize the life of the disc.
  • alloys
    alloys
  • cutoff
    cutoff
    Step that prepares a slug, blank or other workpiece for machining or other processing by separating it from the original stock. Performed on lathes, chucking machines, automatic screw machines and other turning machines. Also performed on milling machines, machining centers with slitting saws and sawing machines with cold (circular) saws, hacksaws, bandsaws or abrasive cutoff saws. See saw, sawing machine; turning.
  • cutoff wheel
    cutoff wheel
    Rotating cutting wheel that cuts bar stock, pipe, etc., to a desired length.
