Klubersynth FB 4 Series Lubricants
September 01, 2014
Klüber Lubrication has introduced Klübersynth FB 4 series, an ultra-fine filtered synthetic spindle and hydraulic oil that extends component life and reduces operating costs. Oils in the series are designed to lubricate rolling bearings of high-speed machine tool spindles. They can also be used in hydraulic systems and components, including dirt-sensitive servo valves where cleanliness standards and/or classes are predetermined by the manufacturer.
"The three oils in the Klübersynth FB 4 Series, ISO VG grades 32, 46 and 68, help reduce wear caused by fine dirt particles in the lubricant, and can lengthen component life due to a higher degree of purity of the oil," explained Bill Watson, regional director of marketing and engineering for Klüber Lubrication North America LP. "They also offer fully synthetic base oil, which helps extend oil change intervals and improve total cost of ownership in a hydraulic system."
The products are PAO oils of purity class 15/13/10 in accordance with ISO 4406, and meet HLP requirements of DIN 51524-2.
