Custom Service Solutions Inc. introduces its 12 inch MiJET parts cleaning and collection unit. This new model has a larger diameter opening, permitting users to clean larger parts than the original 8 inch model.
Using one existing shop air-line at your CNC machine, the pneumatically driven MiJET cleans parts and saves money by capturing expensive coolants for reuse. This affordable unit also captures chips for recycling while minimizing the risk of workers inhaling coolant aerosol and having it settle on floors, creating hazardous slippery conditions. Simple one-touch operation allows parts to easily be blown off and cleaned immediately after machining, while your machine continues to cut parts resulting in improved cycle time and increased productivity. MiJET can also be useful at an inspection station to clean off oily parts prior to inspection.
Air is driven out of a nozzle while simultaneously, vacuum suction pulls the valuable coolant into the container. Exhausted air is filtered to levels that can help your facility meet OSHA standards. Air quality is improved, aerosol is reduced, and floors are cleaner, therefore decreasing maintenance time and reducing the cost of expensive cleaning supplies.
MiJET utilizes an existing shop air line and is easy to incorporate into a work cell since no electricity is required. Optional accessories include castors for easy relocation, a parts basket to hold parts during cleaning, and a low-noise Silvent air nozzle.
- coolant
- shop air
shop air
