ORLAS CREATOR Hybrid 3D Printing and Milling Machine
December 01, 2017
The ORLAS CREATOR hybrid 3D printing and milling machine from O.R. Lasertechnology Inc. brings together the benefits of both additive manufacturing and subtractive manufacturing within a single platform to offer a comprehensive manufacturing solution. The advantages of 3D printing complex metal components using the direct AM powder melting process in combination with the OR LASER’s advanced milling capabilities for precision finishing ensure that the ORLAS CREATOR hybrid is a compelling manufacturing solution at an accessible price point for SMEs.
Moreover, the ORLAS CREATOR hybrid goes beyond the capabilities of classical milling and machining, whereby structures and surfaces that are not normally reachable, such as inside contours, undercuts or hidden cooling channels, can be milled effectively. The ORLAS CREATOR hybrid offers all of the 3D printing features of the classic CREATOR , including the full laser power of 250W at a spot of 40 μm; laser processing speeds of 3,500 mm/sec. and a build platform 110 mm (diameter) with a maximum Z-axis of 100 mm.
  • gang cutting ( milling)
  • lapping compound( powder)
  • milling
  • milling machine ( mill)
