QUICK Knurling and Marking Tools
January 24, 2024
QUICK Knurling and Marking Tools Used in Various Industries Including Medical, Aerospace, Automotive and Fitness
Platinum Tooling, the importer and master distributor of live tools, angle heads, marking tools, Swiss tools and multi-spindle tools manufactured by various global suppliers, is now the North American importer of the QUICK® knurling and marking tools from Hommel & Keller.  The announcement was made by Platinum Tooling president, Preben Hansen, at headquarters in Prospect Heights, Illinois, near Chicago.
A longtime global leader in high-end knurling and marking tools, Hommel & Keller manufactures the QUICK® line with a combination of function and innovation. Quality, precision and stability are the key principals used to make QUICK® tools successful. Furthermore, the company prides itself on a rich history of providing customized solutions for its customers.
The QUICK® product spectrum offers innovative solutions for diverse knurling technology applications. For both form knurling and cut knurling, QUICK® fulfills the most stringent quality standards and masters difficult tasks. Knurling tools are available for use on a wide range of workpiece diameters, including small tools for Swiss type lathes from Ø 1.5 mm.
QUICK® marking tools make it possible to mark workpieces in seconds on a variety of surfaces and part geometries.  Through single marking segments, the marking text can be individually customized. Tools are available in two diameters for interchangeable lettering, as well as custom logos.
These tools are used whenever absolute precision and first-rate surface quality are needed. Examples include medical and dental instruments, watches, fishing gear, windshield wiper shafts, barbells, screwdriver bits, fittings, connectors plus welding and cutting equipment.
  • knurling
    knurling
    Chipless material-displacement process that is usually accomplished on a lathe by forcing a knurling die into the surface of a rotating workpiece to create a pattern. Knurling is often performed to create a decorative or gripping surface and repair undersized shafts.
  • wiper
    wiper
Additional Products from Platinum Tooling Technologies Inc.
REV static broaching tools are for use on CNC lathes with or without Y-axis. They offer a patented eccentric bushing which eliminates alignment errors for machines without a Y-axis. The tools have a sturdy two-piece construction and are ideal for smaller runs. They are designed for use in boring…
Rineck offers standard and custom shrink fit tool holders with various connections including CAT, HSK, BT, SK, PSC and straight shank extensions. In addition, ER shrink fit collets are available. For added rigidity, flange or dual contact holders are available for CAT and BT tapers.  A clamping…
The REV motorized broaching tool is designed for use on live tool lathes. Single machine set-up eliminates the need for secondary operation or outsourcing. REV tools are ideal for high production runs, offer easy installation and fast processing time. These tools are designed for maximum rigidity,…
The u-tec patented changing system allows a standard ER output live tool to accept various adapters for different applications. This allows users the ability to have quick changeover of tools on almost any lathe or mill, using a single tool, without having to commit to a quick-change system on the…
Platinum Tooling, the importer and distributor of live tools, angle heads, marking tools, Swiss tools and multi-spindle tools manufactured by various global suppliers, is now the North American importer of the QUICK® knurling and marking tools from Hommel & Keller.
According to Preben Hansen, president of Platinum Tooling Technologies, Inc., “We are now carrying a substantial inventory of live tools for our customers’ machines.  It represents a significant financial and warehouse space commitment that we have made to support the North American machine tool…
Platinum Tooling announced that it has an extensive line of Heimatec tooling available for the new Haas BMT turret. Platinum Tooling is the master importer of Heimatec tools for North America.
Platinum Tooling, an importer of live tools, angle heads, marking tools, Swiss tools and multiple-spindle tools manufactured by various global suppliers, is now importing Henninger Speed Increasers for North America. The announcement was made by company president, Preben Hansen, at the company…
Heimatec Inc. announces immediate availability of marking and cleaning tools from its European partner Andreas Maier, under the AMF brand. The announcement was made by the president of Heimatec Inc., Preben Hansen. “This development brings additional products to our current customers and responds…
Heimatec announces the availability of its Citizen tool program. This line includes both live and static tools for most Citizen lathes. Designed to optimize the machine’s parameters, these precision tools are efficient and cost effective.
