Radius Dressing
Goodson Tools & Supplies for Engine Builders
Address
156 Galewski Dr.
Winona
55987
MN
United States
Phone
800-533-8010
Toll Free Phone
800-533-8010
Fax
507-452-2907
March 01, 2015
Mach-B Grinding Wheel Shaping & Resizing, a division of Goodson, announces that it offers radius dressing. Mach-B can dress for the following radii 132", 116", 5/64", 3/32", 7/64", 18", 9/64" and 5/32". 26" to 42" diameter wheels only.
Maximum thickness is 2-¼" with no minimum. Corner radii only. Dressing wheels will reduce start up time and reduce diamond wear.
  • dressing
    dressing
  • grinding
  • grinding wheel
    grinding wheel
  • shaping
    shaping
    Using a shaper primarily to produce flat surfaces in horizontal, vertical or angular planes. It can also include the machining of curved surfaces, helixes, serrations and special work involving odd and irregular shapes. Often used for prototype or short-run manufacturing to eliminate the need for expensive special tooling or processes.
