Royal Chuck Stop
February 21, 2017
Royal Chuck Stop
The Royal Chuck Stop provides a simple, consistent method for locating short parts in a 3-jaw lathe chuck. The chuck stop enables short parts to project beyond the chuck jaws, providing clearance for facing operations.
The Royal Chuck Stop is very accurate—front and rear locating surfaces are parallel within +/- 0.0004". Because the Royal Chuck Stop eliminates the need to bore soft jaws, machine setup time is reportedly greatly reduced.
The captive, web-shaped design of the Royal Chuck Stop eliminates the dangers of using spacers and parallels that could come loose and be thrown from a spinning chuck. Three strong magnets further secure the stop to the chuck face.
  • chuck
    chuck
  • clearance
    clearance
  • lathe
    lathe
  • parallel
    parallel
Additional Products from Royal Products
According to Royal Products, ID gripping is often overlooked as a workholding option, yet in many situations it is the best choice. For example, it allows for access to the entire length of the workpiece so all external surfaces can be turned in a single operation, ensuring perfect concentricity.
Royal Products' new Filtermist Ultra is a portable solution for oil mist and smoke that combines Filtermist with cyclonic technology to remove additional pollutants.
Royal Products, a leading live center manufacturer known for custom designs, has standardized five live center point styles.
The Royal Products Chuck Stop provides a simple method for locating short parts in a 3-jaw lathe chuck.
Royal Products has introduced the Econo-Rack, a device that safely collects finished parts as they come off of any bar-fed CNC lathe.
For over 30 years, the Royal Filtermist has been effectively collecting mist and smoke generated by all types of machinery.
