Rustlick Ultracut 380R
Rustlick is excited to announce the release of a new premium, ultra-long lasting semi-synthetic coolant, Ultracut 380R. Ultracut 380R delivers outstanding performance in a wide range of machining and grinding applications.
R&D Chemist, Leroy Hitchcock, explains, "Ultracut 380R uses the newest lubrication and antimicrobial technologies for a coolant that provides an ideal balance of operating performance and durability in the sump."
Ultracut 380R is a number one choice for manufacturers working for industries as diverse as aerospace, automotive, agriculture, energy, industrial components, job shops, plastics, transportation or anyone looking for a maximum performance coolant that lasts. Ultracut 380R reportedly delivers proven resistance to microbials, like bacteria and fungus, and is shown to last longer than competitive coolants without the need for costly additives.
In independent lab studies, Ultracut 380R lasted longer and outperformed top competitors in bacterial and fungal resistance. This hard water stable formula is effective in a wide range of light, moderate and heavy-duty applications, including machining, cutting, grinding, milling, broaching, threading and turning.
"Ultracut 380R is great for aluminum applications because it won't stain the metal like other semi-synthetics," states Hitchcock.
Ultracut 380R contains no DCHA (dicyclohexamine), chlorine, boron, phenol, nitrites, triazines, sulfur, copper, or SARA 313 reportable chemistry and it is easy to recycle or dispose of with conventional techniques and equipment. Rustlick Ultracut 380R is available in 5 or 55 gallon containers and is recommended for ferrous and nonferrous metals, aluminum, titanium, brass, bronze, copper, and other high-nickel alloys.
  • alloys
    alloys
  • broaching
    broaching
    Operation in which a cutter progressively enlarges a slot or hole or shapes a workpiece exterior. Low teeth start the cut, intermediate teeth remove the majority of the material and high teeth finish the task. Broaching can be a one-step operation, as opposed to milling and slotting, which require repeated passes. Typically, however, broaching also involves multiple passes.
  • coolant
  • gang cutting ( milling)
  • grinding
  • milling
  • threading
    threading
  • turning
