Thread Mills
August 13, 2012
Ultra fine grain, solid carbide thread milling cutters save more time and money than traditional tapping, especially for large diameter threading. Start producing full threads to within one pitch of the bottom of your drilled holes with Guhring's thread milling cutters.
The company offers options to help users drill and chamfer a hole in one pass. Find out more about its 450 standard thread mill sizes (both solid and coolant fed). Use a free "Thread Milling Program Generator" to program your CNC machines at www.guhring.com.
  • coolant
  • gang cutting ( milling)
  • milling
  • milling machine ( mill)
  • pitch
    pitch
  • tapping
    tapping
  • threading
    threading
Additional Products from Guhring Inc.
Guhring has just introduced a new drill family to the U.S.: the RT 100 XF. A new proprietary carbide grade, developed by Guhring specifically for the RT 100 XF, demonstrates the wear resistance to meet the demanding requirements of high-production machining and the durability to survive in less…
Guhring’s HPC precision clamping chucks offer extremely high clamping forces while maintaining extremely tight concentricity tolerances, making it an ideal solution for milling operations, as well as drilling and reaming applications. It excels in both heavy-duty and high-speed machining…
The RT 100 S drill from Guhring was especially developed for the complex machining of steel materials. It reportedly scores points thanks to high cutting values and consistently good hole quality. An especially stable and accurate cutting edge is produced thanks to the special micro-geometry.
The RF 100 Diver family of high-performance, solid-carbide endmills from Guhring Inc. are capable of plunging and extreme ramping in alloy steel, cast iron and aluminum. The Diver is a variable-helix, 4-flute endmill with a special face geometry for drilling up to 2 diameters deep and ramping up to…
