You Ji YV-600E2T VTC
February 18, 2016
Designed for large lot-size machining of big aluminum wheels or similar parts, the You Ji YV-600E2T Vertical Turning Center (VTC) is described as a compact, high-precision, heavy-duty machine suitable as a stand-alone machining cell or integrated with other machines to form a complete flexible manufacturing system, according to a Feb. 11 news release issued by Absolute Machine Tools Inc., Lorain, Ohio.
Among the highlights of the VTC:
  • A maximum swing of 33.4" and a maximum turning diameter of 29.5".
  • Rigid vertical column and base are Meehanite castings, heavily ribbed for reduced thermal distortion and vibration dampening.
  • The X and Z axes employ roller-type linear guideways.
  • Specially designed sliding covers inside the machine are said to virtually eliminate chip problems.
  • All ways are completely enclosed, while a forced lubrication system ensures high-precision production.
  • The high-speed way systems enable rapid traverse rates of 787 in./min.
  • Precision “Class 3” ballscrews are driven directly by the servo motors, eliminating belts or gears for more exact machining.
  • The spindle construction is of a heavy-duty design incorporating double roller bearings as well as 45-degree angular contact thrust bearings. The 100-HP high-torque spindle motor drives the spindle via belts, providing plenty of power for heavy-duty machining and the high speeds necessary for fine finishing.
  • Twin 6-position hydraulic vertical hex turrets are mounted on the rams with tough bolt-on tooling.
  • flexible manufacturing system ( FMS)
    Automated manufacturing system designed to machine a variety of similar parts. System is designed to minimize production changeover time. Computers link machine tools with the workhandling system and peripherals. Also associated with machine tools grouped in cells for efficient production. See cell manufacturing.
  • rapid traverse
    rapid traverse
  • turning
PRODUCTS
09/12/2024
The NVH G-EAR system can identify potential gear defects at the component level prior to gear box…
09/12/2024
The versatility of the Protomar Mini is proven through its application in multi-diameter machines,…
09/07/2024
SmartBox 2.0 leverages MTConnect technology to deliver real-time manufacturing data, allowing shops…
