The 360 Series Endmill from Precision Cutting Tools
Published Date
February 19, 2019 - 04:00:pm
Precision Cutting Tools has improved it’s 360 series endmill for 2019. The design consists of the eccentric OD, a sharp corner, a larger gullet and a ground 1° radial land. The series increases metal-removal rates and minimizes chatter. The endmill is ideal for aluminum milling applications. This tool also comes standard with our PVD Diamond Coating, Exxtral Carbon, for up to 3 times more tool life. All these characteristics lead to improved accuracy, higher speeds and feeds, machining longer DOC and superior surface finishes.
For more information visit us at http://www.pct-imc.com/
  • chatter
    chatter
  • endmill
    endmill
  • gang cutting ( milling)
  • land
    land
    Part of the tool body that remains after the flutes are cut.
  • milling
  • outer diameter ( OD)
  • physical vapor deposition ( PVD)
MEDIA
06/26/2024
05/01/2024
04/24/2024
