Abanaki's SS mighty mini
Published Date
February 22, 2016 - 04:45:pm
The SS mighty mini is ideal for removing oil from machining centers and parts washers. The portable unit can service multiple parts washers and coolant sumps, avoiding the expense of multiple units. The belt picks up the oil, which is then scraped from both sides by dual wiper blades at a rate of up to 2 gph (7.6 lph).
Visit the Abanaki website to learn more.
  • centers
    centers
  • coolant
  • wiper
    wiper
MEDIA
06/26/2024
05/01/2024
04/24/2024
