Ceratizit Introduces WTX, First Four-Fluted Drill
Published Date
November 01, 2020 - 05:15:pm
Video demonstrates WTX-HFDS Solid Carbide Drills with applications including grey cast iron with spheroidal graphite and at tolerances of H7. The unique four-flute design of the WTX enables extremely high feeds in steel processing with quick chip removal. The distribution of force to four cutting edges, four continuous spiral-through coolant holes and new CERATIZIT Dragonskin Coating all result in a longer tool life.
The innovative pyramid geometry of the WTX ensures extremely aggressive and precise drilling performance. Positioning accuracy of 0.03 mm, excellent centering properties, superior surface finishes and low burr formation eliminate the need for reworking and subsequent deburring.
Click here for more information.
  • burr
    burr
  • centering
    centering
    1. Process of locating the center of a workpiece to be mounted on centers. 2. Process of mounting the workpiece concentric to the machine spindle. See centers.
  • coolant
MEDIA
06/26/2024
05/01/2024
04/24/2024
