CERATIZIT MonsterMill: solid carbide milling cutters for carbon-fiber reinforced plastics
Published Date
July 30, 2021 - 02:15:pm
As awareness for energy-efficient solutions grows, there is increased demand for lightweight composite components. But composite material properties sometimes present challenges for manufacturers due to their extreme tensile strength and complex structure. The MonsterMill FRP CR has patent-pending geometry that delivers compression across the entire cutting length resulting in the prevention of projecting fibers, multiple use option, and economical programming of the machine. To conquer issues like high abrasiveness and low tool life, the MonsterMill FRP offers a milling range with innovative geometries and cutting edges for fine and coarse pitch. This offers optimal process security, cutting quality, and performance. Click here for more information.
  • gang cutting ( milling)
  • milling
  • pitch
    pitch
  • tensile strength
    tensile strength
    In tensile testing, the ratio of maximum load to original cross-sectional area. Also called ultimate strength. Compare with yield strength.
MEDIA
06/26/2024
05/01/2024
04/24/2024
