A chilling question
Published Date
June 14, 2015 - 11:00:am
Episode 60 of the Grinding Doc Video Series involves a shop that was cylindrical grinding a 50mm diameter part that proved to be out of spec despite in-process gauging that showed otherwise.
About the Grinding Doc Video Series: Thanks to his work as an independent grinding consultant and the author of the "Ask the Grinding Doc" column in Cutting Tool Engineering magazine, Dr. Jeffrey Badger routinely receives questions about grinding from shops all over the world. Through the magazine column and this video series, he provides shops with the insight and guidance they seek.
For more information about the Grinding Doc, visit his website here.
  • cylindrical grinding
    Grinding operation in which the workpiece is rotated around a fixed axis while the grinding wheel is fed into the outside surface in controlled relation to the axis of rotation. The workpiece is usually cylindrical, but it may be tapered or curvilinear in profile. See centerless grinding; grinding.
  • grinding
MEDIA
06/26/2024
05/01/2024
04/24/2024
