Dormer Pramet product tour traverses planes, trains and more
Published Date
November 14, 2018 - 02:30:pm
Brian Norris, president of The Americas for Dormer Pramet, spent a few minutes during IMTS 2018 to guide Cutting Tool Engineering Publisher Dennis Spaeth through a number of product highlights from Precision Twist Drill, Union Butterfield, Dormer and Pramet.
Among the highlights:
  • Dormer's Shark Line taps color-coded for different material applications, including the Yellow Shark for structural, plain carbon and low alloy steels, the Red Shark for alloy steels, the White Shark for cast irons, and the Blue Shark for stainless steels.
  • Union Butterfield's FlashTap Service offers a selection of semi-special tap products as an option for companies that require non-standard thread forms and need them within 48 hours.
  • Pramet's new all-in-one indexable cutter, the Force AD. The milling inserts, which fit both end mill and face mill cutter bodies, are ideal for applications requiring high metal removal rates.
  • Precision Twist Drill's aerospace skin drills, which are manufactured to National Aerospace Standards.
  • A disc milling cutter, which is used to maintain the correct form of railroad rails, features a series of tangentially clamped indexable cutting inserts.
  • alloy steels
    alloy steels
    Steel containing specified quantities of alloying elements (other than carbon and the commonly accepted amounts of manganese, sulfur and phosphorus) added to cause changes in the metal’s mechanical and/or physical properties. Principal alloying elements are nickel, chromium, molybdenum and silicon. Some grades of alloy steels contain one or more of these elements: vanadium, boron, lead and copper.
  • cast irons
    cast irons
    Cast ferrous alloys containing carbon in excess of solubility in austenite that exists in the alloy at the eutectic temperature. Cast irons include gray cast iron, white cast iron, malleable cast iron and ductile, or nodular, cast iron. The word “cast” is often left out.
  • gang cutting ( milling)
  • milling
  • milling cutter
    milling cutter
  • milling machine ( mill)
  • stainless steels
    stainless steels
  • tap
    tap
  • twist drill
    twist drill
    Most common type of drill, having two or more cutting edges, and having helical grooves adjacent thereto for the passage of chips and for admitting coolant to the cutting edges. Twist drills are used either for originating holes or for enlarging existing holes. Standard twist drills come in fractional sizes from 1¼16" to 11¼2", wire-gage sizes from 1 to 80, letter sizes A to Z and metric sizes.
MEDIA
06/26/2024
05/01/2024
04/24/2024
