Feed the Speed with TungFeed-Blade
Published Date
July 26, 2021 - 01:45:pm
Tungaloy’s TungFeed-Blade is an extremely rigid modular blade series for grooving and parting applications. TungFeed-Blade consists of a triangular CHGP style modular blade with three insert pockets which holds a CHTBR/L robust style tool block. Intended for high feed grooving and parting, the TungFeed-Blade system extends insert life, improves surface finish, and part straightness, while significantly reducing cycle time.
  • feed
  • grooving
    grooving
  • parting
    parting
    When used in lathe or screw-machine operations, this process separates a completed part from chuck-held or collet-fed stock by means of a very narrow, flat-end cutting, or parting, tool.
MEDIA
06/26/2024
05/01/2024
04/24/2024
