Grinding Meets Erosion!
Published Date
July 26, 2021 - 12:45:pm
Two technologies, one machine: The new VOLLMER VHybrid 360 combines the strengths of an innovative grinding machine and a proven powerful erosion machine. Allowing you to switch between the two functions in no time! Efficient processing and powerful machining of carbide tools with diameters of up to 50 mm.
  • grinding
  • grinding machine
    grinding machine
MEDIA
06/26/2024
05/01/2024
04/24/2024
