Guhring Solid Carbide Drill RT 100 InoxPro – 50% Higher Feed Rate in Stainless
Published Date
February 02, 2024 - 02:03:pm
Guhring introduces a breakthrough in drilling stainless steels with the RT 100 InoxPro solid carbide drill. This innovation combines carbide, geometry, and a specially tailored coating, resulting in exceptional performance. The drill extends tool life and reduces machining times, addressing challenges posed by stainless steel's high temperatures, tendency to jam, and promotion of tool wear.
Stainless steel's unique properties make it challenging for traditional drills, often leading to tool breakage and reduced performance. Guhring's RT 100 InoxPro, is a solid carbide drill designed for precision in stainless steels and titanium materials. It boasts high cutting values and an extended tool life.
Guhring addresses the challenge of material adherence to cutting edges by incorporating smooth tool surfaces in the RT 100 InoxPro. The drill features polished flutes and a high-quality surface, effectively minimizing built-up edges. This effect is further enhanced by the application of Guhring's Perrox coating, ensuring both smoothness and providing robust wear protection. The optimized geometry of the drill is specifically designed to prevent jamming in stainless steel, resulting in improved wear resistance and overall consistency.
Tests indicate that the RT 100 InoxPro's wear rate is up to three times lower than comparable tools from competitors. Higher feed rates in stainless steel are demonstrated in practical examples, showing a 25% reduction in machining time per component compared to a competitor's drill, while maintaining the same tool life.
  • feed
  • flutes
    flutes
  • stainless steels
    stainless steels
  • wear resistance
    wear resistance
MEDIA
06/26/2024
05/01/2024
04/24/2024
