Guhring's System 222 for grooving and parting-off
Published Date
February 14, 2022 - 12:00:pm
Guhring Inc. highlights the features of its System 222 (two cutting edges, 22 mm length) for grooving and parting-off in this brief video. Carbide inserts have chipbreaker and cutting geometries pressed into them during sintering for maximum consistency. Left-hand, right-hand and neutral insert designs provide optimal productivity. Square shank and parting blade toolholders are available with or without coolant through.
  • chipbreaker
    chipbreaker
    Groove or other tool geometry that breaks chips into small fragments as they come off the workpiece. Designed to prevent chips from becoming so long that they are difficult to control, catch in turning parts and cause safety problems.
  • coolant
  • grooving
    grooving
  • parting
    parting
    When used in lathe or screw-machine operations, this process separates a completed part from chuck-held or collet-fed stock by means of a very narrow, flat-end cutting, or parting, tool.
  • shank
    shank
  • sintering
    sintering
    Bonding of adjacent surfaces in a mass of particles by molecular or atomic attraction on heating at high temperatures below the melting temperature of any constituent in the material. Sintering strengthens and increases the density of a powder mass and recrystallizes powder metals.
MEDIA
06/26/2024
05/01/2024
04/24/2024
