Iscar Multi-Master 145 degree spot drills
Published Date
March 31, 2023 - 12:00:pm
The multi-master (MM) modular milling system from Iscar USA has many possible configurations to fit your machining application. In addition to the standard MM head options, Iscar also offers special ground heads to meet your special machining requirement. The company is excited to introduce a new option for the MM line, a 145-degree drilling head that can be used to center drill or chamfer an existing hole.
Visit the Iscar website here for more information about the Multi-Master modular milling system.
  • center drill
    center drill
    Drill used to make mounting holes for workpiece to be held between centers. Also used to predrill holes for subsequent drilling operations. See centers.
  • gang cutting ( milling)
  • milling
MEDIA
06/26/2024
05/01/2024
04/24/2024
