ISCAR Small Diameter Milling Tools
Published Date
October 01, 2022 - 12:00:am
ISCAR introduces small diameter milling cutters with indexable inserts in the diameter range of 6 mm to 12 mm. These new tools provide an excellent alternative for other solid carbide endmills intended for diverse applications such as shoulder milling, pocketing, slotting and more.
  • gang cutting ( milling)
  • milling
  • slotting
    slotting
    Machining, normally milling, that creates slots, grooves and similar recesses in workpieces, including T-slots and dovetails.
MEDIA
06/26/2024
05/01/2024
04/24/2024
