ISCAR's new Penta 17 line now for Swiss and Miniature Machining
Published Date
April 09, 2019 - 09:30:am
Iscar's latest addition in the PENTA series introduces a new 5-cornered insert for machining miniature parts. The unique shape and design of the insert rekindles this legacy insert by opening new frontiers for additional applications. Standard inserts now available in a wide range of widths from 0.010" – 0.125", with different edge configurations for parting, grooving, back-turning, side-turning, profiling and threading. The insert and toolholders enable the machining of miniature parts with right and left capabilities next to the shoulder of the workpiece. In addition to shouldering capabilities, the tool features a short head, suitable for smaller Swiss and miniature machines. Just like the Penta 24 and Penta 34 before, the Penta 17 design allows for access of the screw for indexing the insert from either side of the toolholder. The chip deflector is ideal for accurate machining and provides excellent repeatability.
For more information visit Iscar at https://www.iscar.com/index.aspx/countryid/1
  • grooving
    grooving
  • parting
    parting
    When used in lathe or screw-machine operations, this process separates a completed part from chuck-held or collet-fed stock by means of a very narrow, flat-end cutting, or parting, tool.
  • profiling
    profiling
  • threading
    threading
  • toolholder
    toolholder
MEDIA
06/26/2024
05/01/2024
04/24/2024
