Kyocera MEAS milling cutter demo
Published Date
July 16, 2020 - 04:30:pm
Kyocera Precision Tools Inc. has released a milling line for high-speed aluminum applications. The MEAS series is engineered with unique grooved insert pockets for added stability when machining at high speeds. Utilize simultaneous three-axis machining with a maximum ramping angle of up to 20°. MEAS allows a broad range of applications, from facing, shouldering, slotting and profiling to pocketing, ramping and plunging.
  • gang cutting ( milling)
  • milling
  • profiling
    profiling
  • slotting
    slotting
    Machining, normally milling, that creates slots, grooves and similar recesses in workpieces, including T-slots and dovetails.
MEDIA
06/26/2024
05/01/2024
04/24/2024
