LinX - The Evolution of the Linear Motor
Published Date
December 29, 2015 - 12:45:pm
Looking for a way to reduce grinding cycle times and improve cutting tool quality in order to satisfy customer requirements, Myles most recently invested in an ANCA MX7 Linear CNC tool grinder with linear motors. The LinX® Linear Motor consists of a shaft containing magnets and a forcer containing wound copper coils. The symmetric design results in zero attractive forces between the forcer and shaft, greatly reducing the loading requirement on support bearings. The thermal barrier design separates and removes heat from the motor, eradicating thermal growth for the machine. So ANCA Linear machines don’t require a dedicated chiller, reducing power and floor space requirements.
Video report posted as a supplement to "Case Study: How a tool producer keeps its edge," a feature article posted along with the December 2015 issue of Cutting Tool Engineering.
  • grinding
  • linear motor
    linear motor
MEDIA
06/26/2024
05/01/2024
04/24/2024
