Meet the Okuma V920EX Vertical Lathe
Published Date
August 26, 2019 - 11:00:am
The Okuma V920EX vertical lathe increases productivity by providing stable machining of thin and odd-shaped workpieces. With a max turning diameter of 36.22 inches and max turning height of 33.86 inches, this machine is capable of performing powerful, heavy-duty cuts, while the vertical orientation is the ideal platform for running thin-walled parts without distortion. The box-type base and column make a highly dependable, highly rigid structure and the headstock with flange construction minimizes the effects of thermal deformation and vibration, which ensures stable, accurate cutting.
For more information visit us at https://www.okuma.com/
  • lathe
    lathe
  • turning
MEDIA
06/26/2024
05/01/2024
04/24/2024
