New DoForce-Tri 07 Insert Maximizes Shoulder Milling Productivity
Published Date
July 29, 2019 - 10:45:am
Tungaloy expands its DoForce-Tri line of square shoulder milling cutters to include a size 07 insert, with 6 cutting edges for precision milling and insert economy. The DoForce-Tri 07 insert allows the insert density and feed capability to be as high as double that of the conventional, trigonal insert, while maintaining the same D.O.C. This is possible because of the innovative, curved cutting edge geometry on a smaller insert. The insert has 6 cutting edges that include a wiper. The tool also has high wall accuracy because of the optimized insert design. The cutter diameters are available in ranges from ø0.75" to ø1.25" (ø18 mm to ø32 mm) for the cylindrical type, and ø2.0" (ø40 mm and ø50 mm) for the shell mill bore type.
For more information visit us at https://www.tungaloy.com/us/product/doforce-tri/
  • feed
  • gang cutting ( milling)
  • milling
  • milling machine ( mill)
  • wiper
    wiper
MEDIA
06/26/2024
05/01/2024
04/24/2024
