Overloaded wheel?
Published Date
July 05, 2010 - 04:15:pm
Dr. Jeffrey Badger, the host of Cutting Tool Engineering magazine's Grinding Doc Video Series, looks at improving coolant velocity for shops running into loading problems with superabrasive wheels. Such wheels are more problematic than aluminum oxide wheels that wear away more readily, Badger reports in the 10th episode of the video series.
About the Grinding Doc Video Series: Thanks to his work as an independent grinding consultant and the author of the "Ask the Grinding Doc" column in Cutting Tool Engineering magazine, Dr. Jeffrey Badger routinely receives questions about grinding from shops all over the world. Through the magazine column and this video series, he provides shops with the insight and guidance they seek.
For more information about the Grinding Doc, visit his website here.
  • aluminum oxide
    aluminum oxide
    Aluminum oxide, also known as corundum, is used in grinding wheels. The chemical formula is Al2O3. Aluminum oxide is the base for ceramics, which are used in cutting tools for high-speed machining with light chip removal. Aluminum oxide is widely used as coating material applied to carbide substrates by chemical vapor deposition. Coated carbide inserts with Al2O3 layers withstand high cutting speeds, as well as abrasive and crater wear.
  • coolant
  • grinding
MEDIA
06/26/2024
05/01/2024
04/24/2024
