Productive Tooling System for Socket Machining
Published Date
April 09, 2019 - 12:00:pm
NTK's Shaper Duo tools are effective alternatives to traditional approaches for socket machining, such as end milling and rotary broaching. The insert bars generate less tool pressure than broach methods, and cycle time is greatly reduced due to an efficient machining process. The system generates better socket tolerance and corner edge sharpness. The tooling is designed for positioning in the back spindle of Swiss machines. NTK carries a selection of insert bars capable of machining T6 up to T30 hexalobular sockets, hexagon size ranging from 1.5 up to 12mm, and square sockets ranging from 1.9 up to 8.1mm AF range.
For more information viist NTK at http://www.ntkcuttingtools.com/
  • broach
    broach
    Tapered tool, with a series of teeth of increasing length, that is pushed or pulled into a workpiece, successively removing small amounts of metal to enlarge a hole, slot or other opening to final size.
  • broaching
    broaching
    Operation in which a cutter progressively enlarges a slot or hole or shapes a workpiece exterior. Low teeth start the cut, intermediate teeth remove the majority of the material and high teeth finish the task. Broaching can be a one-step operation, as opposed to milling and slotting, which require repeated passes. Typically, however, broaching also involves multiple passes.
  • gang cutting ( milling)
  • milling
  • slotting machine ( shaper)
    Vertical or horizontal machine that accommodates single-point, reciprocating cutting tools to shape or slot a workpiece. Normally used for special (unusual/intricate shapes), low-volume runs typically performed by broaching or milling machines. See broaching machine; mill, milling machine.
  • tolerance
    tolerance
MEDIA
06/26/2024
05/01/2024
04/24/2024
