Tungaloy Enhances T9200 Steel Turning Inserts with New Grades and Geometries
Published Date
January 22, 2020 - 01:30:pm
Tungaloy has expanded its T9200 CVD grade insert series to include T9205 and T9235 grades as well as the -TSF and -TM style chipbreakers. Both T9205 and T9235 provide outstanding wear resistance in the P05 and P35 application ranges surpassing existing CVD grades. These capabilities are possible due to Tungaloy’s innovative coating technologies, including:
  • Extremely wear resistant Al2O3coating in a thick and uniformly aligned layer
  • Ultra-hard ceramics for the outermost layer
  • PremiumTec – Tungaloy’s exclusive post surface treatment technology
T9205 and T9235 provide long and stable tool life which maximizes productivity. Combined with the -TSF and -TM style chipbreakers, this latest line meets needs in a wider spectrum of steel turning applications. This expansion complements the preceding T9215 and T9225 grades of the T9200 series.
  • ceramics
    ceramics
  • chemical vapor deposition ( CVD)
  • turning
  • wear resistance
    wear resistance
MEDIA
06/26/2024
05/01/2024
04/24/2024
