TungForce-Rec | Miniature Shoulder Milling Cutter with Incomparable Stability
Published Date
April 10, 2019 - 07:30:am
Tungaloy’s TungForce-Rec, a new miniature shoulder milling series, features a unique clamping system offering exceptional stability in machining small pockets and slots. A shoulder milling cutter that's ideal for minature and general applications. Its V-shaped insert bottom guarantees excellent stability in high speed machining operations.
For more information visit Tungaloy at https://www.tungaloy.com/us/product/tungforce-rec/
  • gang cutting ( milling)
  • milling
  • milling cutter
    milling cutter
MEDIA
06/26/2024
05/01/2024
04/24/2024
