Walter Cut MX grooving and parting off tool
Published Date
February 01, 2020 - 02:15:am
The Walter Cut MX grooving and parting tool improves accuracy, stability and process reliability by improving on proven technology. The self-aligning, tangential clamping of the MX system and the dowel pin location in its insert seat result in greater precision and repeatability. Inserts are offered in five different geometry types with Tiger∙tec® Silver PVD coating for grooving, parting, profiling and thread turning.
For more information visit us at https://www.walter-tools.com/en-us/Pages/default.aspx
  • grooving
    grooving
  • parting
    parting
    When used in lathe or screw-machine operations, this process separates a completed part from chuck-held or collet-fed stock by means of a very narrow, flat-end cutting, or parting, tool.
  • physical vapor deposition ( PVD)
  • profiling
    profiling
  • turning
MEDIA
06/26/2024
05/01/2024
04/24/2024
