EWN 04-7 Boring Head
BIG Kaiser has announced the addition of the EWN 04-7 Series, reportedly the smallest precision finish boring head on the market, for use on micro-milling machines with high-speed spindles such as HSK-E25, E32 or E40.
February 13, 2013
The head features a high precision adjustment accuracy of .0005″ per diameter and .0001″ per diameter through the use of a Vernier scale, and a diameter range of .016″ to .276″ (04mm-7mm). The product is available with the Kaiser KA1 modular connection, or with a Ø10mm straight shank, and can accept boring bars with 4mm shanks. The head features a maximum through-tool coolant pressure of 300 PSI.
While this boring head is accustomed to micro-machining applications, it can also solve problems for companies that need a tool able to travel into deep cavities for ultra-small diameter boring. High rigidity and secure clamping of the boring bar makes it a good product for any micro boring application.
“The EWN 04-7 Series adds to the variety and versatility of our micro-machining program,” says Jack Burley, BIG Kaiser vice president of sales and engineering. “This helps us give customers the best possible solutions for any small-diameter boring needs.”
  • boring head
    Single- or multiple-point precision tool used to bring an existing hole within dimensional tolerance. The head attaches to a standard toolholder and a mechanism permits fine adjust…
  • boring bar
    Essentially a cantilever beam that holds one or more cutting tools in position during a boring operation. Can be held stationary and moved axially while the workpiece revolves arou…
