Improve Processes to Keep Inspection Costs in Check
Delivering accurate and repeatable machining processes is the foundation for curbing inspection expenses.
May 1, 2026By Christopher Tate
Most shops rely on their shop rate to set pricing or cost (if you are in a cost center). Inspection and inspectors are part of the fixed expenses that make up the cost to operate the shop. Unfortunately, inspection is a non-value-adding activity, which for today’s conversation means it adds cost without adding revenue to offset the expense. So why do we spend time inspecting if it adds cost to the parts?
Simple. Because we don’t want bad parts. Bad parts also cost money, and inspection is the way we mitigate the risk of bad parts. It is also an activity that is so ingrained in machinists that it travels from generation to generation like a genetic mutation.
Probably because we are taught from the beginning to measure twice and cut once. Perhaps also because our old habits have yet to catch up with modern machining processes that are far more capable than those in use around the time the genetic mutation occurred. Therefore, we are conditioned to inspect away process defects that should be designed out. Under coercion, I have been baptized in the corporate continuous improvement Kool-Aid.
Even after several forced immersions I remain a lean manufacturing heathen and haven’t given myself over to all of the cult’s beliefs. However, I have become a devout believer in process capability, sometimes known as statistical process control (SPC). Process capability and associated calculations would fill a text book, though most shops don’t need to know all the statistical calculations. They only need to understand the concepts that are intended to drive accuracy and repeatability.
Accuracy in machining is like accuracy in archery. A very accurate process delivers part dimensions that are always very close to the bullseye or nominal dimension. Repeatable machining processes create parts with dimensions that are always the same. When the process is accurate and repeatable, then it is capable.
Creating machining processes that are aimed at delivering accuracy and repeatability is the foundation of reducing inspection and associated costs. Look around the shop and examine what people are doing. Most likely, you have machinists standing at machines, unloading parts and then checking them with various gauges. Sometimes they find an anomaly with a gauge and make an adjustment like changing a tool offset or adjusting a boring head to keep things on size.
Have you considered what happens in these normal man-machine interactions and how they impact the bottom-line? The first thing I think about are machine tool crashes. It has been my experience that machine tool crashes are almost always a result of someone interacting with the machine in an attempt to resolve a dimensional problem. Iam sure you have seen this play out in your shop.
A machinist will measure something and determine an adjustment is needed. They go to the offset page in the control and enter 0.100 instead of 0.001, an honest mistake.
The next thing you know the tool is plunging into the work piece at full rapid. In the best case you have a broken piece of carbide and scrap part. In the worst-case scenario you end up replacing a spindle. The other scenario is one of lost productivity.
Less skilled operators running parts may run into a dimensional problem they cannot resolve. Whether it’s from a lack of confidence or training, they don’t attempt to resolve the problem. Instead, they wait for a more senior person to do so. The result is lost productivity and increased costs.
For these reasons, inspection can be a burden rather than a benefit. So how do you reduce inspection? First, you have to believe it is possible. Machinists and engineers need to overcome the genetic mutation and scholarly training that drives them to measure and adjust.
This is the real hurdle. All other hurdles are easily overcome when the craftsmen believe inspections can be reduced. It’s a big hurdle. Once you believe it can be done, it is necessary to ask, “why do you measure that?” Or, “can we check fewer parts?” Answers to these questions will begin to drive process improvements for accuracy and, ultimately, repeatability.
Process improvements can come in the form of better cutting tools, different machining techniques or higher quality machine tools. Remembering that the goal is to stop checking and adjusting. Sometimes it’s necessary to go slow in order to go fast. Meaning that a reduced machining cycle time could improve the overall efficiency of the process.
At a previous employer we struggled to meet productivity requirements. The speeds and feeds of the improved process were approximately 20% slower than the original. It seemed counter intuitive and many thought the only way to improve was to make chips faster. Making chips faster ignored the underlying problem, which was the insanely long inspection times required whenever we changed a cutting tool.
Our first step was to use the tool as long as possible and keep the doors on the machine closed. We purchased a custom tool for the process and slowed the rotational speed while increasing the flute count to maintain the linear traverse speed. The result was an extremely stable machining process that ran uninterrupted for multiple shifts. Here is where some debate might start.
Some will say that reducing inspection by improving capability is easy when you are running high volume. True, it is easier when you have high production runs. There is far more opportunity to identify and mitigate the problems. However, shops that run low volume parts can still benefit.
Raw materials, cutting tool materials and machine tools remain constant. Look for successful processes that can be copied and propagated throughout the shop. For example, If you have a turning tool that finishes very well in 4140 steel and is always successful, make it the standard finishing method. Same thing for drilling and tapping.
Look for the combinations that are accurate and repeatable and discard those that are not. If specific techniques like helical entry into pockets is a proven method for your shop, then keep using it. Work to make improvements so it becomes a highly capable process. It won’t matter how many different parts you run if you continue to use the capable techniques.
Inspection will always be part of machining; it is a necessity. Reducing or eliminating inspections will reduce costs and help out the bottom line. Imagine how effective a talented machinist could be if their expertise could be spread across multiple machines where they are simply monitoring and not adjusting. Costs would stabilize, production schedules would be more accurate, job satisfaction could be improved and hiring might be easier.
