IMTS 2016 Preview: Machine Tools & Accessories
Cutting Tool Engineering provides coverage of more than 210 of the products that exhibitors will showcase at IMTS 2016. They are divided into tooling and workholding products, machine tools and accessories, and metalworking products. Presented here is the preview for Machine Tools & Accessories.
August 12, 2016
MULTITASK LATHES. The MULTUS U series of general-purpose, multitask CNC lathes from Okuma America Corp. includes two machine sizes. The MULTUS U3000 has a maximum diameter of 25.6" (650.24mm) and a bed length of 39.4" (1,000.76mm), and the MULTUS U4000 has a maximum diameter of 27.55" (699.77mm) and a bed length of 59.05" (1,499.87mm). A rigid traveling column allows cutting along the entire Y-axis. The Thermo-Friendly Concept controls thermal deformation.
Okuma America Corp.
Booth: S-8500.
WHIRLING MACHINE. Leistritz Advanced Technologies Corp. offers the LWN-90 whirling machine for producing gear worms with short cycle times. When properly implemented into a production environment and paired with induction-hardening equipment, the whirling method eliminates thread rolling, thread milling and thread grinding while improving overall worm quality, according to the company. The machine has a 4,000-rpm, 5kW (6.8-hp) whirling spindle.
Booth: N-7061.
TOOL GRINDERS. In FX series CNC tool and cutter grinders from ANCA, LinX linear motors that ANCA Motion designed and built provide axis motion in the X and Y axes. The company's FX Linear machine range covers a broad industry spectrum for light manufacturing, regrinding and production grinding. Its best performance and productivity range is for tools up to 12mm (0.472") in diameter. It offers grinding capabilities for tools up to 200mm (7.87") in diameter.
ANCA
Booth: N-7414.
HYBRID MACHINE. Mitsui Seiki USA Inc.'s Vertex 55X-H combines additive manufacturing and subtractive machining in one machine tool platform. The vertical toolchanger. See automatic toolchanger." title="CNC machine tool capable of drilling, reaming, tapping, milling and boring. Normally comes with an automatic toolchanger. See automatic toolchanger." aria-label="Glossary: machining center">machining center incorporates a spindle-adapted-laser, direct-energy-deposition/powder-feed nozzle to 3D-print parts. The nozzle loads into the toolchanger like a conventional tool and is changed automatically via CNC program prompts. The hybrid machine can print new parts or add material to existing parts.
Booth: S-8519.
HORIZONTAL MACHINING CENTER. Toyoda Machinery USA's FA1050 5-axis HMC is suitable for boring, endmilling, threading and U-axis machining. Spindle support from four heavy-duty bearings—double-row cylindrical roller bearings and dual angular-contact thrust bearings—eliminates vibration, claims the company. A solid cast iron base combines with a full-plate clamping mechanism that develops up to 26,000 lbs. (11,793 kg) of table clamping force. The machine has a 60-hp (44.13kW) spindle drive motor.
Booth: S-8519.
BORING MILL. UnionChemnitz says its KCG boring mill closes the gap between a classic boring mill and a jig boring machine. The enhanced positioning accuracy and geometrical precision is achieved via hand-scraped linear guide ways and optimized ribbing for increased stiffness of the machine bed and column. Measuring devices in all axes continuously monitor machining performance. A highly stable table that has a ground surface enables accurate machining of challenging workpieces, according to the company.
UnionChemnitz
Booth: S-8596.
GUNDRILLING MACHINES. Mollart Engineering Ltd.'s Omnispring 4- and 6-spindle, knee-type gundrilling machines are suitable for simultaneous high-speed drilling of oil holes in multiple automotive transmission shafts. The machines can drill a series of offset holes to varying depths in the ends of the shafts using the 3-axis movements of the machine. The machines have a FANUC 35i control and drives package.
Booth: S-9290.
MILLING MACHINE. Kent USA Inc. equips its KTM-4VKF-E knee-type milling machine with the Acu-Rite MillPwr G2 control. According to the company, the efficiency-driven CNC allows for fast setup and short run times through conversational programming. The machine is suitable for various industries, including aerospace and automotive.
Kent USA Inc.
Booth: N-6756.
CRANKSHAFT GRINDERS. AZ spa offers the DU single-wheel-carriage and the DU2W double-wheel-carriage crankshaft orbital grinding machines. The machines have a welded base structure made of a composite material designed via finite element analysis. The headstock is made of a thermally stabilized cast iron. The tailstock is equipped with an air-suspension system that eases manual movement along the table.
AZ spa
Booth: N-7262.
CNC GRINDER. Schütte LLC says its 325linear 5-axis CNC grinder with linear-drive technology ensures no part play and no backlash. The grinder has extended X- and Y-axis movement and two auxiliary slides for workpiece clamping. On the machine's A-axis, a user can install collet, hydraulic-expansion or multiple-range chucks. With the automated collet changer, workpieces with different diameters can be clamped with high concentricity in the unmanned loader station. The A-axis configuration also permits position-oriented clamping of nonrotationally symmetrical workpieces.
Schütte LLC
Booth: N-7516.
COMPLEX-PART MACHINING. Star CNC Machine Tool Corp. offers the 10-axis SR-38/B for machining complex, large-diameter parts. With the efficient Star motion control system, B-axis versatility and an 8-spindle back-working unit, the machine accommodates complex geometries in one operation, according to the company.
Booth: S-8874.
AUTOMATED CELL. Versatech LLC offers the VersaCell robotic machine-tending cell to help manufacturers mitigate the workforce skills gap. It uses robots to perform machine loading and tending functions. This reduces personnel requirements for a two-machine production center by as much as 66 percent, according to the company. An operator just loads parts onto the included conveyor or drawer system and unloads the completed parts. With the drawer system, multiple parts can be staged for machining.
Versatech LLC
Booth: N-6297.
OD GRINDER. Weldon Solutions' Midas CNC OD grinder features an optical gage system for an automated production environment. This system uses optics to measure multiple diameters and lengths on a large family of pinion gear shafts. The gage communicates directly with the grinder's in-process sizing gage, providing signals for automatic size control. The benefit of optical gaging is that setup from part to part only requires an operator to enter a new part number.
Weldon Solutions
Booth: N-6850.
CENTERLESS GRINDER. The TGS-CL-6020 centerless grinder from Total Grinding Solutions is configured for through-feed and in-feed grinding. The regulating-wheel spindle's outboard design maximizes spindle rigidity and supports and facilitates material rotation, according to the company. The grinder has a 2-axis CNC wheel dresser and integrated, preloaded rolling guide ways. The honeycomb machine bed also enhances rigidity.
Booth: N-7467.
CNC LATHES. Tsugami/Rem Sales released four Tsugami opposed-gang-tool CNC lathes. The 5-axis B0125-III and 6-axis B0126-III are 12mm (0.472") machines. The B0205-III (pictured) and B0206-III are 20mm (0.787") machines with five and six axes, respectively. To increase rigidity, the electrical control cabinet was moved from inside to outside of the machine, and two additional support ribs were installed in the space that held the control cabinet. The main spindle cross-tool speeds were increased from 5,000 to 8,000 rpm.
Tsugami/Rem Sales
Booth: S-9410.
TOOL GRINDER. The GrindSmart 6-axis CNC grinder from Rollomatic Inc. is for production grinding of a variety of cutting tools. It has a six-station wheel changer with HSK 50E arbors, tested for repetitive concentricity of less than 2µm. The 20-hp (14.71kW) "synchronous" direct-drive grinding spindle offers a constant rpm without creating chatter marks in flutes, according to the company. The SmartChanger swaps out wheel packs via an automatic toolchanger without increasing cycle time.
Rollomatic Inc.
Booths: N-7200, N-7214.
BAR FEEDER. The Express 220 S2 automatic magazine bar feeder from LNS America Inc. loads 12'-long (3.7m) bars with diameters from 2mm to 20mm (0.079" to 0.787") and, with bar preparation, up to 26mm (1.024") to accommodate 20mm machines with 26mm-bar capacity. It features a high-speed headstock-synchronization system that meets the requirements of sliding-headstock machines, and a standard 240mm-wide (9.45") magazine tray. Extended-capacity tray is optional.
LNS America Inc.
Booth: S-8586.
WIRE EDM. GF Machining Solutions LLC says the AgieCharmilles CUT 2000 X wire EDM eliminates pitch and positioning errors that would otherwise result in scrapped parts and higher production costs. End users can achieve ±1.5µm pitch accuracy over a 340mm × 240mm (13.38"×9.45") work area and the same for M-shape form accuracy. Specific calibration tests ensure the machine's performance, according to the company.
Booth: S-8754.
HORIZONTAL HONING MACHINE. The SH-5000 horizontal honing machine from Sunnen Products Co. is an automation-ready system for high-volume processing of small parts, such as gears, turbocharger bushings, valve components and pistol barrels. It handles parts with bore diameters from 1.5mm to 101.6mm (0.060" to 4.0"). The control enables infinite part program storage and intuitive setup, and it features a screen that allows inexperienced operators to run the machine as efficiently as veterans, according to the company.
Sunnen Products Co.
Booth: N-7400.
HORIZONAL BORING MILLS. Fives Giddings & Lewis says its RT 130 and RT 155 horizontal boring mills are priced and sized for job shops. The T-bed, or traveling-column, boring mills move the columns in the Z-axis direction and the tables in the X-axis direction. The machines are configured with a 1,250mm × 1,400mm (49.2"×55.1") contouring rotary table with a 10,000-kg (22,046-lb.) capacity. Low height and flat-floor installation facilitate machine relocation, if necessary.
Booth: S-8109.
TOOL GRINDER. Unison Corp.'s Model 9200 8-axis CNC tool grinder has a 27-hp (20kW), direct-drive spindle and Yaskawa AC servodrive amplifiers. It is suitable for producing medical tools, drills, endmills, burs and reamers. An automatic pick-and-place parts loader/unloader enables continuous grinding. An onboard electric wheel dressing system is optional.
Unison Corp.
Booth: N-6648.
VERTICAL MACHINING CENTER. Enshu USA Corp.'s WE30Ve VMC has an evenly distributed, rigid bridge structure and a 12,000-rpm BT 30 spindle. The spindle drive motor offers a peak output of 17.5 hp (12.87kW) and 61 ft.-lbs. (82.7Nm) of torque. The machine's footprint is 1,400mm × 2,520mm (55.1" × 99.2"), and it can accommodate fixtures up to 350 kg (771.6 lbs.). It comes standard with a 21-tool automatic toolchanger; a rotary pallet changer is optional.
Enshu USA Corp.
Booth: S-8592.
CYLINDRICAL GRINDER. Erwin Junker Machinery Inc. says the Lean Selection speed grinding wheel or other abrasive tool for the purpose of removing metal and finishing workpieces to close tolerances. Provides smooth, square, parallel and accurate workpi…" title="Powers a grinding wheel or other abrasive tool for the purpose of removing metal and finishing workpieces to close tolerances. Provides smooth, square, parallel and accurate workpi…" aria-label="Glossary: grinding machine">grinding machine is ideal for small and medium-size production runs in single- or multiple-shift operation. It is for grinding shaft-type parts, including cutting tool blanks. The machine can grind with CBN or diamond wheels and has a peripheral speed of up to 140 m/sec. (459.3 ft./sec.).
Booth: N-7057.
CENTERLESS GRINDING. Glebar Co. says the centerless grinding process on the GT 610 CNC grinder for automotive manufacturers expedites the development process of fuel injector nozzle valves, leading to reduced tooling costs, lower inventory levels and quicker integration of new technology for prototyping or proof-of-concept grinding of a new part. The process increases the efficiency of centerless grinding prototyping by using a single-disc CVD dress roller as part of the grinding system with the full CNC work wheel dressing.
Glebar Co.
Booth: N-7317.
ADDITIVE MANUFACTURING. The SLM 280HL from SLM Solutions NA Inc. is a metal additive manufacturing system with a build envelope of 280mm × 280mm × 350mm (11.02"×11.02"×13.78"). It features a bidirectional recoater. By laying fresh powder on the build plate in both directions, as opposed to coating in one direction and then returning to a "home" position, build times can reportedly be reduced by 30 percent. The machine's dual-laser configuration also reduces build times.
Booth: N-71.
TOOL GRINDER. Strausak Inc.'s redesigned U-Grind 5-axis CNC tool and cutter grinder features NUMROTOplus tool design and grinding software. Two optional loaders are available: a small-batch loader and full robotic automation. The grinder comes standard with an automatic wheel changer and 12.5kW (17-hp) direct-drive grinding spindle. It has an automatic quick-change system for changing collets and 50-taper toolholders. A touch probe for grinding wheel qualification is optional.
Strausak Inc.
Booth: N-7214.
DEBURRING CENTERS. Techniks Inc. offers sPINner deburring centers for small ferrous and nonferrous parts. The pin media removes light burrs and whiskers from holes, slots, threads, cross-holes, internal cavities and other difficult-to-reach part features. Applications include medical, electronic and aerospace parts.
Techniks Inc.
Booth: W-1075.
MACHINING CENTERS. Rasoma machining centers are available from German Machine Tools of America. For enhanced rigidity, the machining centers have separate X- and Z-axis slides, and the machine head is designed as a monobloc with polymer concrete fill. Thermal stability is aided by cooled motor spindles. Part-to-part time is less than 6 seconds, and turret indexing typically takes less than 1 second.
Booth: N-6924.
SLANT-BED LATHE. The GT-27 SL from Ganesh Machinery is a gang-tooled, slant-bed, CNC lathe with an integrated 1.125" (28.58mm) 5C collet spindle and a 7.5-hp (5.52kW), 6,000-rpm spindle. The machine has a 13.5" (342.9mm) cross-travel to hold ½" (12.7mm) turning and ¾" (19.05mm) ID toolholders. A C-axis and driven tools are available for milling, drilling and tapping. It has a Mitsubishi M70 control.
Ganesh Machinery
Booths: S-8045, S-8048.
LASER SYSTEM. Marubeni Citizen-Cincom Inc.'s L2000 is a 10µm fiber-optic system for high-speed laser cutting. Incorporating the system on a Cincom Swiss-style lathe enables a user to combine conventional Swiss machining and laser cutting in a single machine. The laser system is interfaced to the machine control. The system is modular and not designed for a specific machine, enabling one system to be moved to other machines.
Booth: S-9419.
TURNING CENTER. The Talent 51 MSY CNC turning center from Hardinge Inc. features the company's quick-change, collet-ready spindle, which enhances part accuracy and surface finish. The machine comes standard with live tooling, a subspindle and a Y-axis. It has a 5,000-rpm, 25-hp (18.39kW) main spindle with 2" (50.8mm) bar capacity. The maximum turning diameter is 12.2" (309.88mm) and the maximum turning length is 24.9" (632.46mm).
Hardinge Inc.
Booth: S-8738.
GEAR GRINDER. Reishauer Corp. offers the RZ 260 gear grinding machine, which is suitable for gears with ODs up to 260mm (10.24") and modules up to 5mm (0.197"). The machine can be fitted with one or two work spindles. The version with two minimizes loading times. The grinder can be equipped with a fixed or CNC axis for swiveling the dressing tool.
Reishauer Corp.
Booth: N-7040.
BANDSAW MACHINES. DoALL Sawing Products offers four new automatic, dual-column, enclosed Hercules CNC metalcutting bandsaws in its standard product line: the DC-300CNC, DC-400CNC (pictured), DC-510CNC and DC-750CNC. The enclosed, or "box," bandsaws are primarily for vertical cuts and are suitable for cutting solids, tubes and profiles up to 28" (711.2mm) in diameter. Dual-column machines are ideal for a single cut or serial production cutting, according to the company.
Booth: N-7074.
MULTITASK MACHINE. Absolute Machine Tools Inc. offers Tongai's iTD-2000YBC multitask turning center, which has a 75° bed design for enhanced chip flow and operator accessibility. The bed also simplifies programming the optional Y-axis because the Y-axis is perpendicular to the X-axis, as is the case with a vertical machining center. The X-axis cross-travel is 9.05" (229.87mm), Z-axis longitudinal travel is 23.6" (599.44mm), B-axis subspindle travel is 24.8" (629.92mm) and Y-axis travel is ±2" (±50.8mm) from the centerline.
Booth: S-8536.
FLEXIBLE MACHINING SYSTEM. The multilevel FMS from Fastems LLC offers capabilities that extend from a single manufacturing cell to a fully integrated shop-wide system. It can be controlled by the company's MMS5 software operator interface. The interface can also be integrated with other manufacturing plant software, such as enterprise resource planning and material requirements planning. It is compatible with MTConnect.
Fastems LLC
Booth: S-9178.
BORE GRINDERS. Nagel Precision Inc. says its SPV clamp bore grinders are a cost-effective alternative to double-disc grinders, especially when bore-to-face perpendicularity is critical. An example is transmission gears. The grinder can be equipped with up to three grinding heads, and the servodriven index table can hold up to eight chucks. Multiple grinding heads permit multiple-pass operations.
Booth: N-7072.
MULTITASK MACHINE. EMCO Corp.'s Hyperturn 45 mill-turn machine features main and counter spindles, two tool systems, a stable Y-axis, thermo-symmetrical machine construction, compact dimensions and intelligent automation. A 3-axis port in the machine permits automated loading and unloading. The machine can include deburring and cleaning stations.
EMCO Corp.
Booth: S-8780.
LOADING SYSTEM. Liebherr says its rotary loading system (RLS) offers high-efficiency production with one or two machining centers and promotes machine utilization of more than 90 percent. The RLS 800 is for workpieces weighing up to 800 kg (1,764 lbs.), and the RLS 1500 is for workpieces up to 1,500 kg (3,307 lbs.). Both handle workpieces with diameters up to 1,300mm (51.2").
Liebherr
Booth: N-6930.
TURN-MILL CENTER. INDEX Corp.'s G220 turn-mill center has a 5-axis, 18,000-rpm milling spindle and a tool turret with Y-axis. The fluid-cooled milling spindle has hydrostatic bearings in the Y and B axes. The distance between spindles is 1,280mm (50.39"), and the maximum turning length is 1,000mm (39.37"). The machine is suitable for bar stock up to 90mm (3.54") in diameter.
INDEX Corp.
Booth: S-8136.
RIFLING MACHINE. The DeHoff G536-C1 from Kays Engineering Inc. is a CNC machine used to cut rifling grooves into gun barrel blanks. Because the cutting process creates a groove using a single-point cutter instead of deforming it, it does not induce any additional stresses in the barrel, according to the company. The machine is suitable for rifling 22- to 50-caliber barrels 4" to 30" (101.6mm to 762mm) long.
Booth: S-8376.
END-MACHINING CENTER. BLM Group USA says its BC80 end-machining center is ideal for cutting to length, chamfering, facing and measuring bushings up to 3.15" (80.01mm) in diameter and from 0.4" to 13.75" (10.16mm to 349.25mm) long. The bundle loader is available in lengths up to 40' (12.19m). The machine provides in-process part measurement and 100 percent part-length inspection with statistical process control reporting.
BLM Group USA
Booth: S-8470.
WATERJET MACHINE. OMAX Corp. offers the MicroMAX Gen 2 abrasive waterjet machine with a Tilt-A-Jet cutting head as standard equipment. The head virtually eliminates taper when cutting most materials, according to the company. The linear traction drive system uses optical encoders to provide a positioning accuracy of better than 5µm. A steel, epoxy-coated enclosure with sliding doors covers the machine.
OMAX Corp.
Booth: N-6228.
TECHNOLOGY PLATFORM. Mazak Corp. says its Smooth Technology platform incorporates advanced manufacturing cells and systems that enhance part manufacturing processes through smart machines, big data, sophisticated analytics and the Industrial Internet of Things. The Mazatrol SmoothX and Mazatrol SmoothG CNCs are part of the technology platform, which reportedly has transformed the way the company's equipment performs, especially during 5-axis machining and complex contouring.
Mazak Corp.
Booth: S-8300.
ROTARY TABLES. CNC Indexing & Feeding Technologies offers rotary tables from Tan Jia Precision Technology. The rotary tables have an antiwearing worm gear and shaft made of durable high-tensile brass. Encircling brake systems use a large clamping range to prevent displacement during heavy-duty cutting. The tilt rotary tables have a 2+1 independent braking system and large-diameter radial and axial preloaded bearings.
Booth: S-9092.
MILLING MACHINE. The K199 6-axis milling machine is Fidia Co.'s most-compact K series machine and is reportedly ideal for producing small and medium-size molds and prototypes. The machine has a cast iron bed and worktable for high loading capacity, a rotary table for 6-axis capability, a bi-rotary milling head and a C-20 numerical control.
Fidia Co.
Booth: S-8880.
SAWING MACHINE. The Model KASTOwa C7/9 automatic circular sawing machine from Klingelhofer Corp. is for cutting steel bars with thin, throwaway, carbide-tipped saw blades. A saw-blade guidance system with carbide pads helps extend blade life and impart smooth cut surfaces. Blades from 10" to 12½" (254mm to 317.5mm) in diameter and 0.079" to 0.098" (2mm to 2.5mm) thick can be applied.
Klingelhofer Corp.
Booth: N-6670.
MACHINING CENTER. FFG Werke GmbH's Hüller Hille NHB P 80 machining center has a footprint of 16.5 sq. m (54.1 sq. ft.) and offers a rapid-traverse rate of 60 m/min. (196.85 ft./min.) and an acceleration rate of 7 m/sec.2 (22.97 ft./sec.2). A choice of spindles, rotary tables and CNCs allows for flexible configuration. The chain-type magazine has 60 tool locations and can be loaded manually during machine uptime.
FFG Werke GmbH
Booth: S-8129.
CYLINDRICAL GRINDER. United Grinding North America Inc. says the radius version of the S131 internal cylindrical grinding machine combines cutting edge technologies with optimal ergonomics and ease of use. It is ideal for grinding flange parts and small workpieces common in the machine tool, drive element, aerospace and toolmaking industries.
Booth: N-6800.
FINE-GRINDING MACHINE. Supfina Machine Co.'s SPIRO F7 fine-grinding machine is suitable for finishing materials that range from soft plastics to aluminum to steel to hard ceramics. The machine can achieve a plane parallelism of less than 1.0µm. It can be customized to meet specific needs for drive performance, loading, filtration and cooling.
Supfina Machine Co.
Booths: N-6299, N-6394, N-6398.
CENTERLESS GRINDER. Koyo Machinery U.S.A. Inc. offers the C6060 centerless grinder for workpieces from 5mm to 150mm (0.197" to 5.906") in diameter. Users can apply conventional or CBN grinding wheels. A dual-supported, high-speed spindle enables long dress intervals and short cycle times. A low thermal-displacement technique improves cold-start performance, according to the company.
Booth: N-7347.
DOUBLE-COLUMN MACHINE. Hurco Cos. Inc.'s BX40i double-column, or bridge-type, CNC machine has an 18,000-rpm motorized spindle and weighs 20,062 lbs. (9,100 kg). The machine is built with size-45 roller rails on all axes, has linear scales standard and is equipped with the integrated Hurco MAX5 control, which provides multiple programming options. These include conversational, industry-standard NC and a Hurco feature called NC/conversational merge.
Hurco Cos. Inc.
Booth: S-8319.
MILLING CONTROL. The NUMmill control from NUM Corp. is suitable for a range of milling applications, including metalcutting, woodworking and plastic machining. The CNC offers an extensive suite of canned cycles, ranging from simple center drilling, boring and threading to pocket cycles and complex profile milling cycles. For all cycles, 3D simulation enables preprocess verification.
NUM Corp.
Booth: E-4837.
VERTICAL MACHINING CENTER. The QP5X-400 from Chevalier Machinery Inc. is a 40-taper VMC for 5-axis simultaneous or 4+1 applications. The standard machine is integrated with a 2-axis, 12.6" (320mm) trunnion table with a heavy-duty, three-piece, cross-roller bearing, reportedly providing excellent part loading and machining capability, and accommodates workpieces up to 220 lbs. (100kg). The X-, Y- and Z-axis travels are 20.5" (520.7mm), 15.8" (401.3mm) and 15" (381mm), respectively.
Booth: S-8986.
TOOL GRINDER. Vollmer of America Corp.'s Vgrind 160 CNC 5-axis grinding machine is for producing solid-carbide cutting tools up to 50mm (1.97") in diameter. According to the company, the core of the machine is the new kinematics system, which is controlled by two vertical spindles. This is because, unlike a grinder with a single spindle or horizontal double spindle, the vertical arrangement enables multilevel machining.
Booth: N-7066.
VERTICAL LATHE. Famar S.r.l says the operating system for its ERGO vertical lathe is simple but accurate. The fast and stable pickup spindle allows the lathe to load and unload itself. The machine can be customized for an end user's production requirement by adding milling, grinding and hobbing capabilities, as well as any automation system.
Famar S.r.l
Booth: S-8966.
MACHINING CENTER. Takumi USA offers the H-12 bridge-type, double-column machining center. According to the company, the CNC machine enables fast throughput with an inline, direct-drive spindle. The close proximity of the spindle to the bridge casting reduces overhang and the ladder design of the bridge enhances support to the head casting. Direct-coupled ballscrews reportedly increase accuracy.
Takumi USA
Booth: S-8420.
VERTICAL MACHINING CENTER. The DCV2018A-5AX from Yeong Chin Machinery Industries Co. Ltd. (YCM) is a 5-axis VMC with an 18,000-rpm, HSK A63 spindle. The reinforced double-column structure allows for smooth axial movements and low vibration to impart fine surface finishes. The universal 5-axis head has an integral motor and provides resolution accuracy of up to 0.001°.
Booth: S-8450.
CUTOFF MACHINE. The Easy-Cut semiautomatic cutoff machine from Rush Machinery Inc. is for cutting carbide and HSS rod and tool ends. The capacity is from 1⁄8" to 1¼" (3mm to 32mm). The fully enclosed machine with flood-coolant capability features air-actuated workpiece clamping, a workpiece stop with LCD readout, a hydraulic feed cutting stroke with a neutral button for manual positioning and feeding, and automatic shutoff.
Rush Machinery Inc.
Booth: N-7233.
UNIVERSAL MACHINES. GROB Systems' G-Series 5-axis machining centers have a retractable spindle and swivel-rotary table to enhance workpiece accessibility, even with long tools. The series includes the G350-Generation 2, which can machine a part up to 600mm (23.62") in diameter and 600mm high. By redesigning the tool magazine, the overall width of the machine has been reduced from 2,450mm (96.5") to 2,000mm (79.7").
GROB Systems
Booth: S-8574.
CONTROL FOR MILLS. The Acu-Rite MILLPWRG2 CNC from Heidenhain Corp. is for vertical knee and bed mills. It is available with an optional auxiliary machine interface and spindle control console, offering users the ability to use common interfaces and control the host machine tool's spindle.
Heidenhain Corp.
Booth: E-5226.
MACHINING CENTERS. Yamazen Inc. offers the compact SPEEDIO machining center line from Brother International Corp. All models feature the Brother C-00 control. The machines have high-speed spindles, up to 27,000 rpm, and high-torque spindles, up to 10,000 rpm. Nachi's FLEX-S robotic cell is for the S300/S500/S700 models.
Yamazen Inc.
Booth: S-8640.
BROACHING MACHINES. In addition to hard broaching machines, such as the one shown, Broaching Machine Specialties Co. offers hard broaching tools, helical broaching machines and tools, CNC broach sharpening machines, dry broaching machines, and spline rolling machines and tools.
Booth: N-7229.
MULTITASK MACHINE. The Model s1919FTLR 7-axis turn-mill machine from Bumotec SA, part of the Starrag Group, is for manufacturing complex shapes from hard materials in a single setup. The machine combines grinding, milling, turning, gear profile generation and deburring. The advantages of machining complex parts in a single cycle include quick changeover, high productivity, reduced floor space and minimal part handling. The machine is driven by a FANCU linear motor.
Bumotec SA
Booth: S-8696.
HORIZONTAL MACHINING CENTER. New versions of the a51nx (pictured) and a61nx horizontal machining centers from Makino Inc. provide expanded machining capacity through several productivity-enhancing features. These include a vision system for broken-tool detection, enhanced levels of inertia active control and Geometric Intelligence technologies. Also shown will be the a71nx 50-taper, 500mm (19.69") HMC with standard direct-drive NC rotary table.
Makino Inc.
Booth: S-8700.
TURNING CENTER. Doosan Machine Tools America offers the Lynx 2100 series for turning parts up to 350mm (13.8") in diameter and 550mm (21.7") long. The X and Z axes are fitted with rigid, roller-type guide ways. The 15kW (20-hp) motor enables turning outer and inner surfaces and U-drilling. The machine comes with a 6,000-rpm turning spindle and 6,000-rpm subspindle, which enables back-end machining of a workpiece.
Booth: S-9100.
HORIZONTAL BANDSAW. The HBE Dynamic series horizontal bandsaw from Behringer Saws Inc. is suitable for application environments that range from production-cutting service centers to job shops. It has a servodriven down-feed control that automatically adjusts blade pressure, reportedly creating an optimal balance of feed rate and pressure for improved part quality, cutting rates and blade life. An electric, ballscrew-driven material feed gripper eliminates backlash and ensures precise material positioning.
Behringer Saws Inc.
Booth: N-6844.
SINKER EDM. The EA8PS sinker EDM from MC Machinery Systems Inc. has a thermal-displacement compensation system and Z-axis cooling mechanism to improve accuracy by tracking and compensating for machine temperature changes. The Z-axis design uses high-quality ballscrew and linear-motion guide components. These provide excellent positioning accuracy during high-speed jump machining, according to the company.
Booth: N-6815.
HORIZONTAL MACHINING CENTER. Methods Machine Tools Inc. offers the KIWA Triple H40 HMC with a column-traverse structure. The machine can support flexible mounting of various fixtures and rotary tables, based on the application. The stationary table design enables long workpieces to be firmly clamped to the table, eliminating the back and forth action of moving parts with special guarding and allowing access to either end of long workpieces.
Booth: S-9119.
MILLING MACHINE. The KBF 900 CNC milling machine from Knuth Machine Tools USA Inc. has a heavy-duty bed and a Siemens 808 D control. According to the company, the large table, 1,102-lb. (500-kg) weight capacity and 45° swivel head make the machine versatile enough for a range of applications.
Booth: N-6268.
HYDRAULIC PRESSES. Greenerd Press & Machine Co. Inc.'s hydraulic presses include a fully automated, 750-ton, 49'-long × 41'-wide (14.9m × 12.5m), high-speed, horizontal draw press. Presses are available in a variety of styles, from gap-frame and straight-side to die-spotting and forging presses, with production capabilities to 40,000 tons and bed sizes exceeding 20' (6.096m).
Booth: N-6412.
THREADED WHEEL GRINDERS. Gleason Corp. added the 200/260GX threaded-wheel grinding machines to its Genesis series. The GX machines have two spindles to minimize idle and setup times. The software-guided setup of the machine allows operators to change from one workpiece to another within 20 minutes using one tool.
Gleason Corp.
Booth: N-7000.
PROFILE MACHINING CENTER. Handtmann CNC Technologies Inc.'s PBZ HD 600 high-speed, 5-axis profile machining center is suitable for cutting aluminum, composite and steel profiles. The machine is 6m (19.7') long and enables 5-sided profile machining of workpieces up to 30m (98.4') in length.
Booth: S-9136.
FLEXIBLE STACKING CELL. The FSC 600 machine-loading cell from Felsomat USA Inc. is built on a fabricated base for easy transportation and quick installation. The base contains any cutting fluids that may be required in the machining process and prevents those fluids from migrating to the floor. The cell has active basket hanger locks that ensure an accurate and uninterrupted loading sequence.
Felsomat USA Inc.
Booth: N-7040.
VERTICAL TURNING MACHINE. EMAG LLC says the design of its VL 4 vertical turning machine allows for diverse manufacturing capabilities and increased flexibility when soft and hard machining a range of chucked components. With the ability to easily interlink any number of machines, automation can be customized to fit an end user's needs.
EMAG LLC
Booth: N-6834.
MACHINE CONTROLS. Mitsubishi Electric Automation Inc. offers the M8 series control. The company says its M800 CNC is for high-speed, high-accuracy machining and multiple-axis, multiple-part system control, while the M80 enables high productivity and is easy to operate. Both have 19" (482.6mm) touch screens with icon-based navigation for intuitive, smartphone-like operation.
Booth: E-4102.
GEAR GRINDING MACHINE. Star SU LLC offers the Samputensili SG 160 gear grinding machine, which grinds gears without coolant. According to the company, this evolution of the gear-generating grinding process enables cycle times of less than 2 seconds, which is shorter than traditional machines.
Star SU LLC
Booth: N-6924.
CYLINDRICAL GRINDERS. Shigiya (USA) Ltd.'s GDP CNC cylindrical grinders have a double-center drive system. The grinders are equipped with NC movable workheads on the left and right sides. The distance between centers can be adjusted without changing the setup to support workpiece lengths from 30mm to 430mm (1.181" to 16.929"). The maximum grinding diameter is 80mm (3.150").
Shigiya (USA) Ltd.
Booth: N-7463.
GUNDRILLING MACHINE. UNISIG says its UNE12 gundrilling machine incorporates a modular design that provides a high level of flexibility in meeting the needs of job shops seeking to maximize productivity. It can drill holes up to 0.50" (12.7mm) in diameter to a maximum depth of 30" (762mm) and is available with one to four spindles via single-spindle and dual-spindle modules.
UNISIG
Booth: S-9159.
  • conversational programming
    Method for using plain English to produce G-code file without knowing G-code in order to program CNC machines.
  • automatic toolchanger
    Mechanism typically included in a machining center that, on the appropriate command, removes one cutting tool from the spindle nose and replaces it with another. The changer restor…
  • cylindrical grinding
  • centerless grinding
    Grinding operation in which the workpiece rests on a knife-edge support, rotates through contact with a regulating or feed wheel and is ground by a grinding wheel. This method allo…
  • broaching machine
    Machine designed specifically to run broaching tools. It is typically designated by operating characteristics (pull, push, rotary, continuous, blind-spline), type of power used (hy…
  • grinding machine
  • machining center
  • center drilling
    Drilling tapered holes for mounting workpiece between centers. Center-drilled holes also serve as starter holes for drilling larger holes in the same location. See centers; drillin…
  • process control
    Method of monitoring a process. Relates to electronic hardware and instrumentation used in automated process control. See in-process gaging, inspection; SPC, statistical process co…
  • turning machine
    Any machine that rotates a workpiece while feeding a cutting tool into it. See lathe.
