AMADA WELD TECH outlines laser welding for canted coil springs
AMADA WELD TECH has outlined a laser welding process for closing canted coil springs used in electrical contacts, connectors and mechanical retention. These ring-shaped springs appear in products such as medical devices, fuel line connectors and battery interconnects.
The company describes aligning prepared wire ends and joining them in a flush butt weld. It identifies fit-up, alignment tooling and argon shielding as factors in controlling oxidation and the shape of the joint.
AMADA supplies the SH-3A Single Point Coiling Machine for forming the springs. AMADA WELD TECH provides the welding equipment and applications support for the joining step.
Edited by CTE Staff from a press release supplied by AMADA WELD TECH.
