Doosan Robotics unveils AI palletizing solution
Doosan Robotics new AI-powered palletizing solution, PalletizHD+, brings the robot, AI, and application controls together in one integrated environment to make palletizing faster, smarter, and easier for manufacturers to deploy and operate. The system, which debuted at Automate 2026, is built on PalletizOS, Doosan Robotics’ proprietary palletizing operating system and "removes the complexity traditionally associated with palletizing automation," according to the company.
July 7, 2026
Doosan Robotics unveils AI palletizing solution image
Doosan Robotics debuted its AI palletizing solution, PalletizHD+, at Automate 2026.
The system, which debuted at Automate 2026, is built on PalletizOS, Doosan Robotics’ proprietary palletizing operating system and “removes the complexity traditionally associated with palletizing automation,” according to the company.
A key advantage of PalletizHD+ is its high-speed performance, Doosan reports. The solution can process up to 11 boxes per minute and is designed to handle multiple boxes simultaneously. This capability is supported by SwiftMove, an AI-based motion optimization technology. Before operation, SwiftMove analyzes the robot’s travel paths and optimizes its motion to enable faster and more stable palletizing. By improving both speed and motion stability, PalletizHD+ helps users increase throughput and shorten the payback period on automation investments.
PalletizHD+ also enhances ease of use through a smartphone-like, intuitive interface. Instead of requiring extensive programming or engineering support, users can enter box dimensions and pallet conditions, allowing the AI to generate optimized stacking patterns automatically. This enables faster changeovers when product types, packaging formats, or box sizes change. Remote support capabilities further improve operational efficiency by helping users check system status, troubleshoot issues more quickly, and reduce response time.
At Automate 2026, Doosan Robotics will also present Scan&Go 2.0, an upgraded version of the solution first introduced in collaboration with MARI at CES 2026. Powered by Physics-Informed AI and advanced 3D vision technology, Scan&Go 2.0 enables robotic arms to autonomously perform complex industrial tasks. At Automate 2026, the company will demonstrate dedicated solutions for sanding and welding applications.
In addition, visitors can experience Doosan Robotics’ broader portfolio of intelligent automation technologies, including End-of-Line (EOL) solutions for case erecting, packaging, and palletizing, as well as robotics education kits.
“Automate 2026 provides an opportunity to demonstrate how Doosan Robotics is expanding beyond collaborative robot manufacturing into intelligent automation across the entire production process,” said Kevin Kim, CEO of Doosan Robotics. “From palletizing and sanding to welding and end-of-line automation, we are applying AI to real industrial environments to help customers achieve measurable improvements in productivity and operational efficiency. We will continue to expand our portfolio of AI-powered robotic solutions that deliver immediate value on the factory floor.”
Join the MFGAxis discussion
Scroll for the next story
