Artificial intelligence expands machine tool capabilities
October 21, 2020 - 11:15am
A Digital Twin creates a virtual replica of a machining environment, revealing potential tooling conflicts without the need for costly dry runs (Photo: DP Technology)The fourth Industrial Revolution promises new efficiencies and productivity gains for manufacturers. Machine tool suppliers are integrating Industry 4.0 capabilities and software companies that are providing powerful new tools such as those that utilize artificial intelligence.
Machine tool manufacturers are creating solutions for job shops. Some recent AI innovations and benefits that machine tool manufacturers have introduced, include:
  • Predictive maintenance: Some tools come equipped with special monitors that track machine components such as a spindle on a mill.
  • Collision avoidance: Systems run applications that simulate the cutting action a few seconds ahead of the live cut, predicting collisions and shutting down the process to prevent damage.
  • Reduced overhead: Machine tools require a massive amount of energy, even when they’re idle. Many machine tools use AI in the form of meters and sensors to evaluate a machine’s energy usage, and make decisions on how to reduce energy.
Machine tools capabilities are augmented by powerful software that can adapt to changing needs and customer specifications such as the ESPIRIT CAM software from DP Technology. The software has the ability to be updated as frequently as new innovations become available.
ESPIRIT’s features, include:
Machine swap
There are many different scenarios that might require a new program for a different machine: an inoperable machine, the need to increase production, or a move from prototype to production. This ESPIRIT feature uses an AI to automatically update a program any time a setup change is made or machine swapped. It can also automatically detect setup changes without manual input.
Automatic links
Users can create a cutting cycle and then AI-driven software can create the fastest and safest positioning between tool operations with consideration of the limits of specific machines. With automatic links, users can set a machine’s prioritization.
Simulation, analysis, and verification
These capabilities take the collision avoidance feature to a new level, including generating a digital twin of the entire machining environment to review a machine’s kinematics, reviewing the potential for collisions, axes overtravel, acceleration exceptions, and other conflicts before making a single cut.
Machine awareness
This feature allows users to define a process plan for a single workpiece independent of the machine and workpiece set up. For example, select the tooling and the cutting strategy, and AI automatically adapts, sequences, and optimizes the list of tasks to be performed.
Stock-aware toolpath
AI-driven software analyzes the real-time state of a company’s stock, eliminating air cuts and minimizing repositioning, which often leads to improved efficiency and, often, significantly reduced cycle times.
Synchronization
Multichannel machines are especially useful because they can concurrently perform different actions. An AI engine automatically synchronizes and sequences the program for optimal use of the machine, and to avoid collisions.
Short-run and production programs
Many times, switching between short runs for small lot sizes and multi-part production runs for larger lots seems like more trouble than it’s worth. With AI machine awareness, job programs can be reorganized, maximizing process concurrency across multiple parts and optimizing cycle times.
Intelligent work coordinates
For tombstone, fixture, and work offset management, an AI engine can offer automatic selection of work offset and coordinate transformations based on its awareness of the job. The system determines local references for every local machining feature and activates the necessary machine functions including RTCP, tilted plane, and dynamic fixture offset.
Capturing best practices
Features such as ESPRIT’s KnowledgeBase eliminate the need for manual recall of a shop’s best machining practices. Instead, it stores them in the software, allowing any operator to access needed information.
With the right tools, automation in a shop can deliver what Industry 4.0 has long promised—highly efficient manufacturing that doesn’t sacrifice safety for speed.
For more information on the ESPIRIT CAM system, phone 805-388-6000 or visit the company’s website by clicking here.
  • fixture
    fixture
  • milling machine ( mill)
  • toolpath( cutter path)
HII, the McClean, Va.-based weapons developer, announced that its MissionTechnologies division was awarded a $209 million contract to support the development and sustainment of the U.S. Air Force’s (…
08/29/2024
At the 2024 IMTS Show, EasyCMM will showcase its Chameleon retrofit CMM motion controller and Mediator CMM software at Booth #134750 in the East Building at McCormick Place, Chicago.
08/28/2024
FABTECH, a metal forming, fabricating, welding, and finishing event will occur in Orlando from October 15-17. This year’s special events, which are free to all attendees unless noted, will feature a…
