Mitsubishi Electric develops digital twin technology for real-time compensation of CNC machine tool errors
Mitsubishi Electric Corporation announced that it has developed a technology that uses a digital twin to correct machine-tool errors in real time on machine tools equipped with computer numerical control (CNC). For more on machine automation, see this related guide.
March 27, 2026
Mitsubishi Electric reported machining-error reductions of up to 50% in tests with RWTH Aachen University in Germany. The tests used an RWTH-owned machine equipped with a Mitsubishi Electric CNC; in vibration tests, compensation was compared with operation without compensation. The result concerns errors caused by cutting-force deformation and is not a general accuracy guarantee for all machines or workpieces.
From April 2023 to March 2026, Mitsubishi Electric and RWTH Aachen University, known for its digital twin expertise, conducted joint research on online edge computing with a high-speed processing unit. As a result, they developed digital twin technology for CNC machine tools that can accurately estimate machining errors and feed the results back into the control system in real time.
The digital twin’s proprietary compact physical model, which is composed of a minimum number of equations, was created using large amounts of data, including axis positions, currents and cutting forces. The data are acquired at a high sampling rate, and only information necessary for estimating machining errors is extracted.
The system estimates machining errors and feeds compensation values back to the CNC in real time, according to Mitsubishi Electric.
Source: Mitsubishi Electric release, March 25, 2026.
Scroll for the next story
