Product Showcase 2022
Designed for processing super hard materials, Agathon's new NEO Laser machine is said to deliver about 100 times higher removal rates when compared to traditional grinding techniques.
NEO LASER MACHINE
Agathon Machine Tools Inc. |
T-A PRO M GEOMETRY INSERT
Part of Allied Machine and Engineering's high-penetration drilling system, the new T-A Pro M geometry insert targets stainless steel and heat resistant super alloy (HRSA) materials.
Allied Machine and Engineering |
INSERT BOX SERIES
Further expanding its Beckett Packaging division, MOCAP recently announced the addition of many new sizes and styles of its Insert Box Series of products.
Beckett Packaging, A Division of MOCAP |
BORING SYSTEM
The BIG KAISER EWA Automatic Fine Boring System from BIG DAISHOWA performs closed-loop boring operations and features a fine boring head capable of handling multiple bore sizes.
BIG DAISHOWA Inc. |
COATED-CARBIDE INSERTS
Ceratizit USA Inc. introduces three new standard coated-carbide ISO-P steel insert grades said to offer up to 20% longer tool life than previous generation grades.
Ceratizit USA Inc. |
SIMULATION SOFTWARE DEMOS
CGTech will demonstrate the latest version of its simulation, verification and optimization software at IMTS 2022. Improvements to Vericut 9.3 focus on smarter data and smarter manufacturing.
CGTech Inc. |
ZERO-POINT TOOLING SYSTEM
With its integrated sensor technology, the MTS 4.0 zero-point tooling system from EROWA Technology Inc. is said to be the first with wireless digital status monitoring.
EROWA Technology Inc. |
SHOP FLOOR MONITORING
FactoryWiz™ Monitoring is said to boost productivity by collecting live machine or process data from the shop floor, creating baseline metrics and identifying process improvement opportunities.
FactoryWiz™ |
INTEGRATED PROBLEM-SOLVING
GF Machining Solutions will showcase integrated problem-solving solutions that include the new CUT X 500 and CUT P 350 Pro wire-cutting EDM machines for precision part generation.
GF Machining Solutions |
SHRINKING, PRESETTING COMBO
The VIO linear tool shrink machine offers a combination of shrinking and presetting technology, is Industry 4.0 compatible and said to be ideal for precision operations.
Haimer USA LLC |
QUICK-CHANGE JAW
The System 3 Quick Change Base Jaws from Huron Machine Products Inc. bolt to your chuck like a standard top jaw and are adaptable for any foreign or domestic power chuck.
Huron Machine Products Inc. |
FLUTE MILLING EXTRA
Ingersoll Cutting Tools offers the NuMax ILockTM with an extra flute per diameter for greater productivity in high-temperature alloys that are used in aerospace components.
Ingersoll Cutting Tools |
SWISS MODULAR QUICK CHANGE
Iscar USA’s new NEO Swiss modular quick-change tooling line for Swiss-type machines features a robust rotary wedge mechanical design for clamping rigidity.
Iscar USA |
DEBURRING CROSS-DRILLED HOLES
J.W. Done Corp. developed the ORBITOOL deburring tool to tackle cross-drilled holes and is capable of removing burrs in-process specifically from the intersection of crossholes.
J.W. Done Corp. |
SLIMLINE ANGLE HEADS
Alberti Slimline angle heads, which are said to offer precision when machining complex parts with limited access, will be among the products featured at Koma Precision Inc.'s IMTS 2022 booth.
Koma Precision Inc. |
AUTOMATIC FILTRATION SYSTEM
The Komline-Barnes Hydroflow Star Filter is a patented, automatic filtration system capable of filtration levels as low as 1 µm to 3 µm (nominal), depending on the application.
Komline-Barnes |
HIGH-TEMP ALLOY DRILLING
Designed for high-temperature alloys and stainless steel holemaking applications, the HI-PERCARB® 143M-S drill series from Kyocera SGS Precision Tools is engineered to combat edge wear and hole deviation.
Kyocera SGS Precision Tools |
HIGH-PRECISION DIAMOND ANNIVERSARY
Lach Diamond Inc. will celebrate its 40th anniversary at IMTS 2022 by showing off a new generation of diamond tools as well as its standard products for high-precision and economical use.
Lach Diamond Inc. |
2-IN-1 ZERO-POINT CLAMPING
The Quick•Point® Combo Plates zero-point clamping system from Lang Technovation Inc. offers two different grid dimensions (52 mm and 96 mm) in one zero-point unit.
Lang Technovation Co. |
6-AXIS CNC TOOL & CUTTER GRINDER
Machine Control Technologies Inc. introduces its MCT6000H series of 6-axis CNC Tool & Cutter Grinder machines with integrated autoloader for your rotary tool needs.
Machine Control Technologies Inc. |
TOUCH PROBES
Marposs will demonstrate its WRP60 high-accuracy touch probes with multichannel radio transmission during IMTS 2022. The probes are designed for high-accuracy, 5-axis machining centers and milling machines.
Marposs |
CNC AUTOMATIC LATHE
With a larger 15” touch screen and sliding back door, Marubeni Citizen-Cincom Inc.'s Swiss-type CNC automatic lathe model L20E-3M125B offers greater accessibility and features a low frequency vibration cutting function.
Marubeni Citizen-Cincom Inc. |
PERFORMANCE ENDMILLS
Mastercut Tool Corp.'s Pro+ Performance End Mills include premium nanocomposite, silicon-based coatings: PowerN (nAC0) and PowerNR (nACRo), which make the tools ideal for hard material machining in high-heat applications.
Mastercut Tool Corp. |
52/96 ZERO-POINT WORKHOLDING
Mate Precision Technologies will showcase its 52/96 Zero-Point Workholding System at IMTS 2022. The system is compatible with similar 52 mm and 96 mm four-post, pull-stud configurations.
Mate Precision Technologies |
COPPER-IMPREGNATED EDM GRAPHITE
Mersen USA Inc.'s new DS4C copper-impregnated EDM graphite material—created using its DarkStar micro-grain technology—is said to be ideal for severe EDM applications and difficult alloys.
Mersen USA Inc. |
TITANIUM DRILLING
The CrazyDrill Cool Titanium drill series from Mikron Tool is tailored to the respective titanium alloys allowing the various types to be machined safely with improved cutting results.
Mikron Tool |
PROCESS IMPROVEMENT
Mitee-Bite Products LLC continually expands its wide range of workholding solutions and design services to all major industries including customers wishing to learn more about process improvement.
Mitee-Bite Products LLC |
HIGH-PRESSURE CLEANING TOOL
The Boost Master gear pump-driven, high-pressure coolant chip removal tool for machining centers boasts an input of 1.5MPa (215psi) and generates a 15MPa (2,150psi) output pressure.
NT USA Corp. |
SPINDLE SPEEDERS
OMG North America introduces MOX spindle speeders for high-speed finishing operations with an output speed up to 36,000 rpm. The heads are adaptable to all CNC machining centers.
OMG North America |
TOOLS FOR AUTOMATIC LATHES
Platinum Tooling Technologies Inc. offers an expanded line of live and static tools for Swiss-type CNC automatic lathes, as well as 1:4 speed increasers for current Citizen models.
Platinum Tooling Technologies Inc. |
ULTRASONIC PROBE
Renishaw Inc.'s new RUP1 ultrasonic thickness measurement probe increases the multi-sensor capability of the company's REVO 5-axis system, which now offers six different probe sensor families.
Renishaw Inc. |
HYBRID PEELING & GRINDING MACHINE
Rollomatic Inc.'s new GrindSmart 660XW 6-axis tool and peel grinding machine allows users to utilize advanced lean manufacturing principles known as the Ultra-Lean Grinding Process.
Rollomatic Inc. |
MOBILE ROBOTIC AUTOMATION
At IMTS 2022, Rollomatic Inc. will unveil its SmartMoma® AGV and Nextage®, which respectively feature an Omron automatically guided vehicle and a Kawada humanoid industrial robot.
Rollomatic Inc. |
PARTS ACCUMULATOR
Royal Products will showcase its Rota-Rack® Parts Accumulator, which is said to be a lean, cost-effective device that enables any bar-fed CNC lathe to run unattended for extended periods.
Royal Products |
CUT-PREPOINT-CHAMFER MACHINEThe CH-CM0406 Cut-Prepoint-Chamfer machine from Rush Machinery Inc. performs three blank preparation functions. Carbide rods up to 23.5” (600mm) long can be cut to length, prepointed and chamfered.
Rush Machinery Inc. |
LINEAR PRECISION GRINDER
Schütte USA's 335linear high-precision 5-axis CNC grinding machine produces and resharpens all types of tools, and is suitable for grinding, milling, polishing and finishing of medical implants.
Schütte USA |
SOLID-CARBIDE THREAD MILLS
Scientific Cutting Tools will introduce new solid carbide thread mills, the NPS/NPSF. The 15° helical flute design aids in reducing side cutting pressure. Shank sizes range from 5/16” to ¾”.
Scientific Cutting Tools Inc. |
AUTOMATED 5-AXIS TOOL GRINDER
At IMTS 2022, Star Cutter Co. will display its newest automated NXT 5-axis tool grinder, which will feature the 28 kW spindle option and four-station wheel change capability.
Star Cutter Co. |
5-AXIS MODULAR GRINDING MACHINE
Strausak Inc. introduces its ONE 5-axis tool grinding machine with NUMROTO tool design software. The next‐generation tool grinding machine is scalable, modular and retrofittable with any option.
Strausak Inc. |
AXIAL FLOATING DEBURRING TOOL
Tapmatic Corp.'s DeBurr-Z axial floating deburring tool for CNC machines allows the tool to follow the edges of the workpiece even when the edges vary in height.
Tapmatic Corp. |
ONE MICRON FILTRATION
Transor Filter USA will debut several improvements to its line of One Micron Filtration systems, including a new and improved design for the company's V-Series Filtration units.
Transor Filter USA |
MODULAR SWISS TURNING SYSTEM
Tungaloy America Inc. is expanding its ModuMini-Turn modular turning tool system designed for use in Swiss-type sliding-head lathes with new exchangeable cutting heads for parting and profiling applications.
Tungaloy America Inc. |
GUNDRILLING FLEXIBILITY
At IMTS 2022, UNISIG will demonstrate how its UNE6 Series small-diameter gundrilling machines excel at drilling deep holes in demanding materials, including high-strength titanium and surgical-grade stainless steel.
UNISIG |
SUPERSONIC THREADING
Vargus USA unveils its new MACH-Supersonic Threading line for thread milling and thread turning applications. The new tools are said to work twice as fast as standard tools.
Vargus USA |
IN THE PORT SEQUENCE VALVES
At IMTS 2022, Vektek Inc. will demonstrate its new In The Port Sequence Valves, which reportedly eliminate the need for complex, multiple circuit deep-hole drilling.
Vektek Inc. |
LASER MACHINING
Vollmer of America debuts its VLaser 370, which is capable of manufacturing and no-contact resharpening ultra-hard cutting tools (PCD, CVD-D and MCD) unmanned around the clock.
Vollmer of America |
AUTOMATED TOOL INSPECTION
Zoller Inc.'s »roboSet 2« automation cell pairs powerful hardware and software for automatic cleaning, measuring, inspection and laser etching of cutting tools to meet customer demands.
Zoller Inc. |
Cutting Tool Engineering
Cutting Tool Engineering Booth: 431668 |
