Tungaloy launches drawing generators and cost savings calculators
Tungaloy says it is advancing its digital tooling solutions with new Drawing Generators and Cost Savings Calculators that were designed to help users move faster, quote smarter, and prove value with confidence. The company says its latest Drawing Generators make it easy to configure and generate accurate drawings for applications—with no delays, no guesswork.
The generators allow users to quickly define special slot cutter solutions for a wide range of grooving applications; instantly generate detailed drawings for solid drills and custom drilling tools, expand capabilities for chamfering, boring, and special tool configurations, and access drawings anytime, from any device.
Drawing generators
Tungaloy Corporation has introduced two new digital tools designed to support customers in evaluating tooling efficiency and cost optimization: the ReamMeister Cost Calculator and the DrillForceMeister Cost Calculator.
These calculators allow users to compare current tooling setups with Tungaloy solutions, providing a clear estimation of potential cost savings and performance improvements.
By inputting basic machining parameters, users can quickly obtain:
- Estimated tool cost per component
- Comparison between existing and optimized solutions
- Potential cost savings and efficiency gains
The tools are designed to simplify decision-making and support data-driven proposals, making it easier to demonstrate the value of exchangeable-head systems in real applications. Both calculators are accessible online and can be used anytime, from any device.
If you have any questions, reach out info@tungaloy-ntk.com
