12 x 36 Inch Engine Lathe
Standard on the #9684510 lathe are 3 and 4 jaw chucks, splash guards, chuck and tool post safety guards and inch and metric gears for threading. Like all Palmgren lathes, it is built and inspected to the DIN 8606 toolmakers precision lathe standard.
Delivering precision, power and versatility, the 12 x 36 inch Engine Lathe from Palmgren is an excellent choice for a wide range of turning operations normally found in much larger machines. Its heavy cast construction, smooth power transmission with helical gears are designed to provide years of trouble-free precision turning.
The #9684510 12 x 36 inch Engine Lathe from Palmgren is an excellent choice for turning small metal parts making it ideally suited for prototype shops, home machinists, jewelry manufacturing, tool rooms and fabrication and maintenance shops.
