13-inch x 40-inch Engine Lathe
Powerful enough to handle heavy metal removal, Palmgren's 13-inch x 40-inch engine lathe also has the accuracy and control for precision fine tolerance tuning. A DRO and glass scales are standard on the lathe for operator convenience and accuracy.
September 25, 2018
The headstock is designed to provide maximum power for roughing cuts and smooth quiet power for fine finishing. The lathe is available with either a 1 PH, 2 HP or 3 PH, 3 HP power motor.
